Results 1 to 10 of 10
    Mar 2011
    Minnearusta
    difference between car and truck hemi??
    Hello all, I am new to this forum. I am looking at buying a 2006 Magnum Awd with a lurched hemi ( cylinder number 7 has no compression). I have been looking for a engine and all I have found was used for $2500plus tax. At the same yard I found one out of a 2006 1500 regular cab with low miles for $1600. Np I know I know I am going to have to change the intake,exhaust manifolds and oil pan but what else is different? I thank you all for the help I can get with my project.
    Jul 2007
    Outside Fargo, ND
    Those are the only differences between them. well dipstick tube and dipstick is different
    JBA shorties catless mids and SLP Loud Mouth I, K/N typhoon, powerbond undrive pulley, 170 tstat, mopar TCM, blue tops, R1 crossdrilled/slotted rotors, HAWK Pads, SRT MAX on 112, CNC Inertia Heads milled, 3000 Edge converter 3.91 Getrag 09 axles installed!#157 of 1400
    157 0f 1400
    http://s182.beta.photobucket.com/use...20563452620283
    Feb 2008
    Naperville, IL
    just make sure the motor is actually a 06 motor. 05 and older truck HEMI motors had many differences. 05 looks like this
    2006 black /SRT//8/
    Autocross videos - (((((SRT8 Charger autocross lap.))))) (((((Edited movie.))))) (((((Helmet cam lap.)))))
    Jun 2010
    Glendale Heights IL
    What are the differences in the 05 and older truck blocks versus the car blocks?
    Feb 2008
    Naperville, IL
    Quote Originally Posted by Ponty56 View Post
    i don't know if anything in the block is different. for sure the ignition system, intake, and accessories are different.
    Union County, NJ
    I've seen three 5.7s with low miles for sale here on LXF for 1200-1500 over the last few weeks.
    www.inertiamotorsports.com
    www.shop.inertiamotorsports.com
    JarZ@inertiamotorsports.com
    512-964-7724
    /510-277-4214
    Find us on Facebook or Twitter or Instagram: @inertiamotorsports
    5.7L & 6.1L Hemi Registry # 856
    Current Mopars:
    2001 Dodge Durango SLT 4.7L 4x4
    Past Mopars:
    2004 Dodge Ram SLT 5.7L HEMI 4x4 - Cam/supercharger/headers
    2005 Dodge Magnum R/T - Cam/heads/headers
    2006 Dodge Magnum SRT-8
    2000 Chrysler LHS
    1999 Dodge Intrepid SE
    Aug 2010
    Gilbert, Arizona
    My 03 Ram doesn't have MDS. There are some holes in the heads that might need to be tapped for the LX accessories. Not really sure tho.
    "A workshop is a Temple where we invoke the blessings of the Gods of invention.
    And seek refuge from the heretics who know not the joy of creating something unique.
    Oct 2008
    miami,fl
    the trucks 5.7 have a different timing cover that positions the accessories differently than on the lx's
    2006 charger srt8*** low comp 426,billet main caps,arp hardware, ported heads,custom cam,xv manifold, air/air front mount intercooler,twin precision billet p6262 ball bearing turbos, ati balancer, 150shot zex perimeter plate no2 system, custom dedicated 1 gallon fuel system for no2,90mm throttle body,paramount performance nag1,2800stall converter(currently upgrading to paramounts 4000 stall),dss axles,stock open diff(currently upgrading to quaife and 3.55 gears),
    900whp+ at 13psi(boost only) on 93oct, well above that when i spray!!!!!
    Diablotoona tuned/tamed the BEASTTTT!!!
    Jan 2010
    mainly what the others have said...but the blocks themselves will be the same...as long as it did have mds. the heads for the majority will be that same...but the holes on the driver head for the PS pump may not me drilled and tapped...but if all you need is the block...swap everything else over and you will be good to go.
    Quote Originally Posted by JarZ View Post
    x2
    Check for sale forum.
