Results 1 to 6 of 6
    Nov 2010
    910 NC
    couple of questions on eagle heads
    Couple quick questions on the eagle heads.... Do they raise compression like the 6.1 heads? Do they have egr? Does the springs need upgrading from stock? Can I use my forged 5.7 push rods? And finally they come on a 5.7 correct but they have a intake and exhaust just like a 6.1 head?
    2004 Dodge ram under construction
    Feb 2010
    North Alabama
    Quote Originally Posted by lvs2gofast View Post
    Do they raise compression like the 6.1 heads? Yes, but more than a 6.1 head will.
    Do they have egr? its cut into the head on the exhaust side. but thats as far as it goes. no exit ont he front of the head. it could probably be made to work. but its better off with out it.
    Does the springs need upgrading from stock? depends on cam. but i would say yes to most any aftermarket cam.
    Can I use my forged 5.7 push rods? nope. not even close to the right length
    they come on a 5.7 correct but they have a intake and exhaust just like a 6.1 head? thats correct. while they still dont use the same manifold/s the port shape on the heads are the same for the new 5.7 intake and exhaust manifolds as all of the 6.1 stuff.
    Hope this helps.
    Nov 2010
    910 NC
    Thanks man. So I have deleted my egr since I have a 6.1 intake, this being the main reason to upgrade. So if I'm running a 8:1 compression motor what will eagles with cometic phuzion head gaskets put me at?
    Lorain Oh
    BFNY Performance
    440-787-7235 8am- 5pm
    BFNYPERFORMANCE@YAHOO.COM
    RIP NHDave
    RIP LOU1355
    Nov 2010
    910 NC
    Damn maybe that's a bad idea...
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    NE Ohio
    Phuzion head gaskets are .0516, using that with a 65cc eagle head will result in 9.25 compression. This is also assuming with 8:1 compression your pistons are negative 10cc
    With stock gaskets it would be closer to the 10.1 Eric said
    2009 B5 Blue Challenger R/T /Billy Briggs 426/ Thitek Heads & Cam /
    Installed By BFNY Performance/
    SHR Trans Paramount 8.8 & Dominator TC /Tuned By Jerseyboy /
    Atco
    Video
