Results 1 to 13 of 13
    May 2010
    Richmond, Va
    New Engine: Max Wedge 413Ci
    We have a new motor that we are working on that is based off of the 5.7 block. The motor is bored and stroked to 413ci for the maximum in hp/tq for your 5.7. The motor is being designed for NA applications and maintains a cylinder wall thickness identical to our 6.1 stroker combinations.
    NA Compression Ratios
    10:1 using 03-08 heads (Ideal truck motor)
    10.5:1-11:1 using 6.1 heads (Ideal 93 octane NA motor)
    11.3:1-12.3:1 using eagle heads (Ideal for 93 octane NA motor)
    Boosted Compression Ratios
    8.8:1 using 03-08 heads (12-15psi capable)
    9.75:1 using 6.1 heads (10-12psi capable)
    10.3:1 using eagle heads (up to 10psi capable)
    For different compression ratios, we can order a custom piston to suit your needs. This motor is really at home as an NA engine.
    413ci Longblock: $7000 (No Core Charge) Only 1 at this price
    Comes standard with Manley crank, rods, and pistons. Iron rings, clevite bearings, camshaft, timing chain, lifters, forged pushrods, eagle mean street heads, cometic head gaskets, and factory main/head bolts.
    In an 09-10 5.7 vehicle, power output is estimated to be 450rwhp/475rwtq due to camshaft and rpm limitations.
    In any non-VVT platform, we are shooting for 500rwhp/500rwtq.
    These estimates are based on a ported 6.1 intake, 90mm tb, longtube headers, free-flowing exhaust, and a custom tune.
    Available options include the following.
    Tool Steel wrist pins: Boosted/N2O
    ARP Main/Head Studs: Boosted/N2O
    Pro-Series I-Beam Rods: Boosted/N2O
    Coated Pistons: Boosted/N2O
    Steel Rings: Boosted/N2O
    Gapless Rings: Boosted and NA applications
    Ported 6.1 Intake
    Longtube Headers
    90mm or 100mm Throttle Body
    Jul 2006
    Quinte West, Ontario, Canada
    Very Cool!!
    The original 413 Max Wedge in '62...
    from maxwedge.com...
    Displacement.................413
    Bore.............................4.19
    Stroke..........................3.75
    Compression ratio..........13.5 to 1 !!
    Horsepower...................420
    Torque.........................470
    2006 Charger R/T with Road & Track
    10.93 @ 125.6
    426 / Apache Heads / 239/247 Cam / Ported 6.1 Intake / 90mm TB / FTI 4400 TC / Getrag 3.23 / Tuned by JerseyBoy
    Dec 2006
    SAN DIEGO, CA
    Quote Originally Posted by Adanac Charger View Post
    Very Cool!!
    The original 413 Max Wedge in '62... from maxwedge.com...
    yep, that's the numbers that they gave NHRA.
    Dec 2009
    Park Hills, MO
    What's the bore and stroke?
    Posted from the Captivate!
    I AM ON MIL DUTY PLEASE EMAIL SALES@EUROCHARGED.COM to contact about TCMs.
    2005 Silver Magnum R/T
    1/8 NA PB: 7.466@91.83mph 1.620 60'
    1/8 N2O PB: 6.947@96.50mph 1.539 60'
    1/4 N2O PB: 10.941@123.71mph 1.539 60'
    Dec 2009
    Park Hills, MO
    Bump
    Jul 2006
    My guess is that they'd use a 4.08 stroke... that would calculate to about a 4.015 bore. ?? Just a guess on the stroke.
    Welland ON
    so if it's 5.7 based, it's not really a wedge is it?
    http://www.lxforums.com/board/signaturepics/sigpic18566_2.gif
    Jul 2006
    Do you mean because it's a stroker and not 'oversquare'?
    Jul 2006
    Well... I have it from a good source that I'm wrong on the 4.08 guess.
    Lorain Oh
    No because it's a Hemi and not a wedge motor(IE:383/413/426/440) from the 60's and 70's.
    BFNY Performance
    440-787-7235 8am- 5pm
    BFNYPERFORMANCE@YAHOO.COM
    RIP NHDave
    RIP LOU1355
    Ft Laud.....
    Quote Originally Posted by fargo59 View Post
    Thats ok ,These really aren't Hemi's either
    Dec 2010
    4.25 crank?
    Dec 2009
    Park Hills, MO
    My guess is a 4.08 crank that has been reground if that is even possible. Rod journal size is probably sub 2.0. And word from Pwr?
