Page 1 of 4 123 ... LastLast
Results 1 to 15 of 46
    May 2010
    Richmond, Va
    PWR Heads and Cam VS Competition Heads and Cam, CAMS ARE DIFFERENT SPECS!!!!!!!!
    I dont want to name any names, but we had a 5.7 customer swap to our heads and cam along with an eagle intake and below are the before/after results.
    This image has been resized. Click this bar to view the full image.
    Feb 2006
    Columbia Ridge, OR
    Ok.
    Well, the Mayans and other Soothsayers were right, the end has begun.
    Common sense is so rare it should be considered a superpower
    Dec 2008
    Albany NY
    Numbers seemed real low before. Look good at 380. Were they swapped for eagle heads too?
    High Comp 392.
    Center of the LX Universe
    Okay... There's a bump in HP and TQ, but pretty meaningless without details.
    2005 AWD Magnum RT. FRI Econo Heads & FRI Sidewinder, JBA Shorties, JBA/HHP hi-flow catted mids, stock SRT8 cat-back, C&L CAI. 12.645@108.18 - RETIRED
    2015 Chrysler 300S - Daily Driver
    Feb 2008
    Mchenry Illinois
    ^^^^x2
    May 2010
    Richmond, Va
    the customer had a competitors heads and cam along with an eagle intake manifold.
    Now he has PWR 5.7 ported heads, PWR cam, and the same eagle intake manifold.
    May 2010
    Richmond, Va
    It was the same tuner for both builds.
    Dec 2007
    Northern Ohio
    Was your cam and head specks comparable to the competitors you took out?
    2007 SubLime || #1035 || Mods: Arrington 440 ci stroker, 90mm TB, roller rockers 5 pt rollbar, American Racing headers and catless mids,Thitek heads, Paramount 8.8 differential, drive shaft, DSS 1400hp axles, Transmission built by Enhanced Transmissions , LMI prototype headlight CAI, Protorque converter, Lots of BT goodies, "Show and Go" install package by BFNY Performance,
    1/4 Best - 11/8/14 10.26 @ 132
    '06 Charger, Magnesium Pearl RT - My awesome DD
    RIP nhDave - Never forgotten
    Bummer. Would have been pretty interesting if you would have keep the intake consistent.
    On to... ...the next
    May 2010
    Richmond, Va
    The intake manifold is the same in both builds.
    The only difference is the heads and cam.
    The competitors heads are listed as their ported heads and the cam had zero specs written on it.
    Dec 2008
    Albany NY
    I heard what kinda cam is in there. Should post the info up and let people make their own asumptions.
    Jan 2009
    Canada
    Sooo are they the same lift cam, same stage heads? This isn't much of a comparison other than they were both 5.7's
    Just lurking. Hemi Registry #1050
    Feb 2008
    Fredericksburg, Virginia
    You don't really compare cams to each other at the same specs. Obviously, the same specs make the same power. There's a lot more to a cam than it's peak lift and duration numbers. What you'd want to compare is cams that are designed for the same thing. Both cams are marketed as mild cams. Neither shakes the car, both cruise like a camry, neither kills gas mileage. They both were designed for the same purpose. The first setup didn't do what was expected. The PWR setup did what it was supposed to and then a little more. More power with zero loss in street manners = superior cam.
    www.EFISpecialties.com
    EFI Tuning Specialist
    8+ years of Tuning the fastes
    t, most powerful Hemis around
    "In theory, there's no difference between practice and theory. In practice, there is."
    Dec 2008
    Albany NY
    So you put a stage 1 entry cam to a stage 3 in the same league?
    Sep 2010
    Orlando, Fl
    What does something like this cost I am interested in getting some more power, also what type of tuning do I need too do. New too these cars
