Results 1 to 5 of 5
    Dec 2006
    Back in Indiana
    Autometer C2 Wideband (model 7178) issues...
    Hey guys, my wideband appears to have gone belly up after working for a couple of days. It was reading around 14-15 at cruise (normal) and lean at WOT, around 14.3 for the first few days. I had it just kinda sitting on the dash and the plug on the back was not staying in very well, fell out a couple of times.
    Well I had my exhaust on kinda half-assed, and when I went to tighten it I found out some jag-off (me) forgot to tighten down the rear 02 sensors all the way. So I tightened them up, and the next day my wideband was stuck at 16.5 (maxed out). I messed with the settings and no matter what I do it stays at whatever the max is set to, although one time I did it get it to sorta bounce between 20.0 and 19.9...
    So I guess my question is this... did I ruin the sensor? Anyone had issues with theirs? Or know what pins I need to check for voltage (did some searching on google and couldn't really find much) or did I screw it up by not having the 02 sensors in all the way? Know how to reset the gauge to factory stock? The instructions are worthless and There's no way my motor is running THAT lean, because I'd assume it would be knocking/pinging/something by now but it runs great.
    Thanks in advance for the help.
    If you can read this, thank a Teacher.
    If you can read this in English, thank a MARINE.
    Sponsored by Billet Technology
    Powered by Franks Racing Inc
    Back to my former Cam Only Record Holder setup.
    [06 300C - 77 F250 460 - 85 Ramcharger 318]
    "I spent a lot of my money on booze, women and fast cars. The rest I just squandered."
    Aug 2009
    Kansas
    I do not personally have one yet, but I've read about people doing the "rag" test on the sensor to see if it will go between lean and rich. That should tell you if your sensor is still good I believe. Use some kind of brake/carb cleaner in a rag and see if it goes rich.
    Dec 2006
    Back in Indiana
    Hmmm haven't heard of that. I'll look it up and try it out. Thanks!
    Lorain Oh
    Mine did that.....I kept playing with the 2 buttons till it worked again....when it fell one of them got bumped.
    BFNY Performance
    440-787-7235 8am- 5pm
    BFNYPERFORMANCE@YAHOO.COM
    RIP NHDave
    RIP LOU1355
    Dec 2006
    Back in Indiana
    That's what I thought too E, I tried changing everything, I was out there for like an hour messing with it. I'll prob give them a call tomorrow and see if there's some kinda factory reset procedure or something. Thanks bud
