Results 1 to 15 of 16
    May 2010
    Richmond, Va
    Eagle Heads *They are Finally Here*
    We have been working on these for a very long time now and they are finally finished.
    These heads are actually out-performing our 6.1 heads on our flow-bench and will be used on most of our builds moving forward. With the new motor going on Andy's car, I imagine a set of these will be going on at the same time. Justin will also be switching over to these in the not to distant future.
    The First 5 sets will sell for $1895 and after that they are $2095.00
    Let me know
    This image has been resized. Click this bar to view the full image.
    Aug 2008
    Newark,DE
    Just curious...how much more CFM are they moving over a similarily ported 6.1 head???
    Inferno Red 06' Charger SRT8...groups I,II,III and sunroof.
    Southern Hotrod P&P heads/SHR-CMG1 cam,HHP/BES ported Intake,BT ported TB,Protorque 2800 stall,Getrag w/3.73's,Kooks LT's/mid-pipes,Corsa cat-back,Carbon Fiber Airhammer CAI,Jet 180 tstat,Diablo Predator with custom CMR dynotune by HHP,BT polished catch can and some BT goodies.
    451RWHP/439RWTQ
    May 2010
    Richmond, Va
    They are pretty equal, just a little more than the 6.1 in a couple areas.
    May 2009
    Springfield VA
    Anyway to throw these onto my build?! I have an eagle intake already!
    2008 300c
    392 Modern Muscle, 6.1 heads Modern Muscle
    6.1 intake and 90 TB, 3.06 Getrag, SHR trans, SRT Headers, Corsa exhaust (Tuned by Dave Foreignmuscle)
    PWR heads and Cam PB; 12.91@108.24mph
    PWR Stroker 12.41 @ 115.77
    New England - CT
    Core charges?
    Do they require a 6.1 exhaust manifold/header. Nvrmnd, looking at the port pictured it looks d shaped so yes I think is the answer.
    426 Power Ported Stroker, 3.06 getrag rear, 3600 FTI stall, Eagle Ported heads w/custom valves, ported TB, SLP long tubes, Silver Box, TZ Chally hood, custom BT, KW V2 Coilovers, Hotchkis sways and custom fabbed End Links
    1969 (oo===]|[===oo)
    2008 (O.|||||||.O) 2006 (Oo.|==+==|.oO)
    Apr 2006
    Huntersville, NC
    What do they do with the compression ratio on a 6.1 block?
    Stock 5.7
    Sep 2008
    raise it a soild point
    but you can get gaskets for that
    PWR 393, Twin 6262mm Turbos, SHR trans, Fore Fuel system, Wilson Hemi Sheet Metal Manifold
    880 RWHP 775 RWT at 16 psi and 17* of timing
    Tuned by Robert@ Ditos motors
    Walk Softly And Carry Two Big A$$ Turbos!!!
    Lorain Oh
    Quote Originally Posted by 8yourM5 View Post
    Why? Just tune for it?
    BFNY Performance
    440-787-7235 8am- 5pm
    BFNYPERFORMANCE@YAHOO.COM
    RIP NHDave
    RIP LOU1355
    Milwaukee, WI
    Whats the core charge on these?
    May 2010
    Richmond, Va
    $800
    Southern Maryland
    Do your Eagle Heads have stock chamber and valve sizes?
    2006 Black R/T- Inertia 5.7 Based 370 with Eagle Big Valve Heads & Custom Blower Cam, Kenne Bell 2.8LC Supercharger with 148mm T/B & CTP'S KB Stand Alone Drive, Heat Exchanger & Oil Fill/Seperator, Paramount Performance Transmission, Dominator T/C & 8.8 Diff w/3.73, DSS 1400HP axels & Drive shaft, Willwood 15" Brake Kit and AFCO Coilovers. Best ET 9.98 @ 136.26 BOOST ONLY
    Feb 2010
    North Alabama
    The valves are manley, 2.08" and 1.575"
    Chamber is worked to be 11:1 on a stock pistons. Chamber work is kinda per order, depending on if its for a stroker, stock 6.1 or stock 5.7 and what the customer whats for a compression ratio.
    Aug 2005
    Pompano Beach, Florida
    So whaddya do if they're going onto a stock piston'd 5.7 now, and eventually go onto a 6.1??
    Hemi Registry 0436 PWR Forged 6.1 block -YSI @20psi -Modern Muscle Performance Stage3+ manifold and custom cam - 90mmTB- Indy Heads - TTI Longtubes - Enhanced(hemi31) TC/Transmission - HemiTuner TCM - BFNY 3.06 Getrag-325/45/17M&H 9.937 @ 138
    Feb 2010
    North Alabama
    Compression ratio would drop going from a 5.7 bore to a 6.1 bore.
    If you changing the short block I would think the easiest route at that point would be to get the pistons to match the compression you want and leave the heads alone
    Milwaukee, WI
    So will these work on a stock 6.1 block with no new pistons? They'll slap onto a stock 6.1 short block?
