Results 1 to 10 of 10
    Apr 2010
    Boston, Best City in the World
    Cam and Crank out of sync
    This has just been a nightmare, after weeks putting in a new (to me) motor, then spendng big bucks upgrading everything else becasue it was running so good (too much stuff to list).
    Now after running great for a few weeks I am getting some strange noises when trying to start the car, and it is running like **** (if it stays running at all). I figured I had a bad starter and the bendix drive was sticking, dragging down the motor. Swapped the starter so Nope.
    Took it to Chrysler (50,000 on an 05 300C but somehow it's not covered) and paid the $100 to have it starscanned (DS Trinity was not getting any codes), they are seeing that my cam adn crank are out of sync. Since I didn't touch my Cam or Crank during the motor swap I am kinda at a loss.
    Pulled a valve cover and rotated the motor by the Harmonic balancer pully, all the valves seem to be opening. So prob not a broken cam.
    Any ideas as my trusty CHrylser techs are shrugged shoulders on this one. If I don't get this fixed this 300 is getting mumifed for the remainder.
    -Joe
    If this was a bad Crank Sensor (Knock sensor???) or cam sensor I would be getting a code
    Jun 2007
    Union co. N.J.
    Maybe the chain tensioner broke off the timing set?
    Worlds first N/A stock motor LX Mopar 11sec.1/4mi. pass! Best SLB 11.660@117.63 1.70 60ft.
    Personal best time - heads, cam, ported intake, tune, 3,975#RW 11.071@126 1.51 60ft.
    So far with 440 - 10.87 @ 126mph
    Billy Briggs 440 with Thiteks!
    Completed and installed at BFNY!
    Tamed at Hemituner Performance!
    San Antonio, Tx
    If the chain had some wear in it and slipped you could be retarded (one tooth off)
    What are the stats on the motor you put in there?
    Posted via LXFMobile
    HULK's Avatar
    HULK is offline West Coast Style Meets East Coast Power
    Aug 2007
    Chicago, IL
    I cant see how they could be out of sync if the car was running great for an extended time prior to this. Sorry I cant help you more here, but Im willing to bet this is a real stupid porblem (something small and minor) that is a headache more than anything else. Therefore, my money is on something electrical.... probably a sensor like you said.
    Good luck with it... dont give up just yet!
    Quote Originally Posted by Simans82 View Post
    Compared to your modding addiction, I'm just looking at the coke on the table. You on the other hand, you're more like Scarface.
    Apr 2010
    Quote Originally Posted by Redfox0099 View Post
    First of all I am sure I am at least one tooth off, not sure about the motor.
    The motor is a stock 5.7 with 22K out of an 07 R/T.
    I was already pulling the front of the motor back off to see what I can see.
    Chrysler techs wanted to pull the tranny to look at the Flexplate sensor I didn't even think we had one of those. (still not sure we do)
    Lorain Oh
    there is no flexplate sensor....there is a crank sensor behind the starter....sounds like you broke the timing chain tensioner to me.
    Aug 2007
    FT LAUDERDALE
    Quote Originally Posted by Hemi31 View Post
    most likely x2
    South Florida
    replace it with a double roller
    Lorain Oh
    Quote Originally Posted by MuscleMan305 View Post
    replace it with stock.....that double roller is a headache.
    South Florida
    I was always under the impression that the doubles were better and easier to adjust.
