Page 1 of 8 123 ... LastLast
Results 1 to 15 of 118
Thread: RPM Surging
    Jun 2009
    Somerset County, NJ
    RPM Surging
    Just had a cam/header install and a tune by Johan done a few weeks ago. Ever since the install I get a little rpm surge while lightly picking up speed in the 1500-1900 rpm range. If I give it a little more throttle it clears right up. Also its more noticeable with the a/c on. This morning I actually noticed it while idleing down my street. Johan tried to help but cant seem to pin it down. Any ideas?
    Inertia Crazy Jay Cam, 6.1L Springs/Rods, Fastman Ported Throttle Body, Tranzformer Shift Kit, NoESP, Mopar CAI, Cherry Bomb Vortex Mufflers, Dyno Tune, 13.16 @ 105mph On Street Tires
    Mar 2009
    Edmonds, WA
    Vaccum leak possible, maybe @ TB? Sometimes these cars just need to settle ina bit with new cams though
    Posted via LXFMobile
    Jun 2007
    Scottsburg, IN
    I have the exact same problem. i thought i was the only one with this problem. even the rpm range is the the same as yours. Johan, bless his heart has tweaked my tune a few times but still seems to be there. If you come across a fix for this let me know. In the meantime Johan will eventually work it out, hopefully. Keep in touch. That surging is really annoying though isnt it.
    Rob
    Rob
    Current Ride - 2012 Dodge Charger 392 SuperBee - Yellow
    2014 Dodge Challenger - HederOrange, R/T Blacktop Edition - Sold
    2006 Dodge Charger Daytona 5.7L - Torred - Sold
    Mods: Diablosport Intune
    Performance: TBD
    Jun 2009
    Somerset County, NJ
    Johan tried to fix mine also but no deal. He thought it might have been my T/C, but I see you have an aftermarket one and still have the same issue. If I find a fix I will definitely let you know
    Apr 2009
    Oakley Ca
    are these cars tuned for the cams
    Just your everyday grocery get'er
    Jun 2009
    Somerset County, NJ
    Mine was tuned after the cam install
    Jun 2007
    Scottsburg, IN
    Mine also. Tuned after cam install. Its scary that mine acts just like his does in the same rpm range. Gotta be a fix for this.
    Apr 2010
    LOWER FLORIDA KEYZ
    I have the EXACT same problem. I just got a Spartan on a 111LSA and heads and Stu and I cant figure it out. It rides great WOT, But when at certain speeds idling and in parking lots its revs up and down. Thats the only flaw.
    Machinist-- When Johan did your tune was it an email tune or on a Dyno in person with him?
    Im going to get a dyno in the near future. I pm Johan today.
    Anybody ever got a dyno by Johan? Results? Sill surging?
    Aug 2009
    East of Houston
    I have the same problem with mine. Showed up after cam install. It got so bad, I couldn't drive at slow speeds without it dying. It bumped up the ide RPM's a bit and that helped the low end drivability. But it still surges under partial throttle around 1500.
    Looks like a trend showing up here. Whoever figures it out stands to get some of my money. lol
    Apr 2010
    LOWER FLORIDA KEYZ
    I hope a dyno can solve this
    Jun 2009
    Somerset County, NJ
    I went with an email tune from Johan.
    im running a Crazy Jay 113 LSA
    Jun 2009
    Somerset County, NJ
    Has anyone had tried switching back to one of the canned tunes?
    Houston, TX
    its in the tune, PM Johan and he will fix it up.
    im sure he knows exactly what the problem is because my car had the EXACT same symptons. first revision from Johan cleared it right up
    '99 FRC Corvette - Far From Stock
    '06 Silver R/T R&T Fully Loaded [SOLD]
    ->FRI'd with Street/Strip Heads + Scud Camshaft<- CTP Spacers + 09 Eagle Manifold
    -FRI Custom Stepped LT Headers--Getrag 3.06 LSD--DIABLOsport Predator--Powerbond 25% Underdrive Pulley--ProTorque 2800
    -FRI PolyMounts--GSM Cold Air Intake--180Tstat--RTJunkieNOESP--MoparTCM--PEDDERS Touring Kit--Billet Tech Throttle Body
    Best ET: 12.490 sec @ 113.58 mph +400 DA, 4000 RaceWeight
    Jun 2009
    Somerset County, NJ
    Ill give it a try, I didnt get a response from him the last time when we were trying to work this out. Could have been a communication thing.
    Aug 2009
    Strasbourg, France
    It's in the tune... Had the same issue with a sidewinder installed with a simple 93 diablo tune.
    No problem anymore with a custom tune made by Bob at SVS.
    Maybe you could try to reinstall your custom tune and just after pull the 11th fuse out. If you don't reset the PCM's memory HAL becomes schizophrenic, trying to overwrite partial new datas and mixing them with old ones. Erase the memory and let HAL learn : 20 mn at iddle with a/c off in park position, 10mn with a/c on, 20 mn at iddle in drive position and you'll avoid most of the iddle and surging problems : its only my own experience but it worked great !
