    Jul 2009
    S.E. michigan
    hey bob, flow question??
    first off, i realize your lx/5.7 reso delete kits are for sound enhancement, & that you make no claims of increased HP.
    but, i was curious if, in your professional opinion, how a 340hp 3 pass exhaust with one of your reso delete kits would compare to a 350hp straight thru exhaust as far as flow is concerned?
    reason i ask is looking at your cutaway thread, it seems pretty obvious that the resonators are the biggest restriction in the 340hp system, with the flattened tubes & all.
    '06 Magnum R/T stock bottom end. Home ported heads milled .030" stock valves, Comp 268 cam, 84mm throttle body, catless factory SRT-8 exhaust from headers to tips, getrag 3.06 with DSS axles, FTI 3200 converter. 180° thermostat, email tune by Johan. 12.63 @ 109. 90,000+ mile DD!
    The resonators are the biggest restriction, IMO, the 3 pass is still a good muffler but not nearly as good as the straight thru.
    Jul 2009
    S.E. michigan
    okay, thanks. i went ahead & ordered one of your 5db kits.
