Results 1 to 9 of 9
    Jan 2008
    VA, but born in that 202 SW
    Dyno in 3rd and 4th gear question?
    Can someone explain this too me please. I watched my buddies charger get dynoed the other day on a dynojet in 4th gear and he told me his numbers would have been higher if they did they dyno pulls in 3rd gear. He mention that he got his car dyno'ed two other time on different dynojet in 3rd gear and his numbers were at least 15 horsepower more. Im confused because i thought everyone did dyno runs in the same gear, but i guess not. So my question are, Why do shops use different gears to do dyno runs and why is their a power difference between 3rd and 4th gear?
    Greenville, South Carolina
    Quote Originally Posted by dwhip View Post
    I know a few things about this. 4th gear is a 1:1 ratio which will be closer to true values. Also for tuning 4th gear is better due to 1:1 ratio.
    If you don't have the speed limiter higher you can't dyno in 4th which I believe is why most do it in 3rd.
    Frank's SPARROW cam, Indy Maxx heads, LMI Fender Pull Intake, Edge High Stall Converter, Full SRT exhaust, 399 rwhp, 407 ft.*lbs.
    5.7 N/A 11 second club Best times to date:
    1/8 mile E.T. 7.369 @ 95.90 mph.
    1/4 mile E.T. 11.60 @ 115.97 mph.
    1.60 60 ft. best
    Feb 2008
    Eastern Shore of Maryland
    I recently had my ride Dyno Tuned by AJ and just as Charger4Life had his car Dyno Tuned by AJ they both were tuned in 4th gear. The only time AJ ran the car in 3rd gear was to chase down a Cat-over-Temp-Protect that was causing the car run rich at the top end of a 4th gear pull. The reason for this is that it took longer for the car to reach top RPM in 4th than in 3rd. So he re-mapped the tables and that was the end of that.
    2010 Challenger SRT /M6 with an ARI 440 rebuilt by Charlie's Machine, Apache heads Ported by Craig of Thitek, Ported 6.1 Intake by Modern Muscle, 90mm TB by ARI, TTi 1-7/8" Long Tubes, Zoomers 3" Exhaust, LMI 4" CAI, Trinity Tuner, BC Racing Suspension, Zeitronix Wideband, Hotchkis Sway Bars and Tuned by Brent @ DTP Racing.
    Feb 2007
    Texas
    All else being equal mine dyno'd higher in 4th than 3rd.
    (Mine also dyno'd lower with the 3.23s than the stockers)...go figure
    2006 Inferno Red Charger SRT8
    K-1 426
    K-1 427
    K-1 428
    SHR trans|Wavetrac&3.23s|DSS shafts
    Built by Cam
    Tuned by Sohfast94
    *Car sold, and missed, September 2013*
    Houston, TX
    4th gear is MANDATORY
    unless... your shop has a Superflow type load dyno.
    a lot of shops dont want to do 4th gear dynos because wheel speed is VERY high (160s or so???) and it can be dangerous to the tires if the car owner has cheap tires.
    ive heard of a couple tire blow out stories on the dyno and its scary.
    same goes for the dyno. its more stress on the dyno
    tell em to suck it up or take your business elsewhere
    you can dyno in 3rd with simulated load and still get an accurate tune.
    i dont know the ifs ands whys or buts about it..
    but i have seen a few local cars get tuned in 3rd (on a dynojet.. not loaded)
    then they hit the street and the tune is off in every gear except 3rd.
    we started pulling 4th gear and tuning in 4th.
    the tune stays consistent thru all gears.
    some one else can try to explain the hows and whys... but ive seen it with my own eyes.
    since then, we only dyno in 4th (on a dynojet)
    Johan and his boys at DS have a superflow, a loaded dyno, and do their pulls in third to keep the wheel speeds down,
    but they cam simulate true load of the street, so its consistent thru all the gears.
    in regards to horsepower readings?
    who cares. its a freakin dyno. its a tuning tool, not a hp calculator.
    the two dynos youve used are just differently calibrated and done read the same anyway regardless of gear.
    p.s.
    ive heard the same as what kingsavage suggested.
    shorter gear ratios in the rear end give LOWER numbers
    and shorter gear ratios in the transmission give LOWER numbers.
    not sure why, it seems backwards to me, but thats what ive heard.
    '99 FRC Corvette - Far From Stock
    '06 Silver R/T R&T Fully Loaded [SOLD]
    ->FRI'd with Street/Strip Heads + Scud Camshaft<- CTP Spacers + 09 Eagle Manifold
    -FRI Custom Stepped LT Headers--Getrag 3.06 LSD--DIABLOsport Predator--Powerbond 25% Underdrive Pulley--ProTorque 2800
    -FRI PolyMounts--GSM Cold Air Intake--180Tstat--RTJunkieNOESP--MoparTCM--PEDDERS Touring Kit--Billet Tech Throttle Body
    Best ET: 12.490 sec @ 113.58 mph +400 DA, 4000 RaceWeight
    Feb 2008
    Quote Originally Posted by dudeiwin86 View Post
    p.s.
    The way it was explained to me is that it takes less torque and HP to spin the drum with shorter gears so the gears are doing more of the work than the engine.
    Feb 2007
    Texas
    Interesting thread...
    I was at SVS a few months ago...from their web site: "Superflow SF 840 autodyn chassis dynamometer"
    We were checking out an oddity with how my transmission/tc were acting in 3rd gear.
    I wasn't too concerned about the top number but I noticed a couple of interesting things:
    Call the base 3rd gear dyno number X. Dyno'ing in 4th gear yielded X+~15 and this was recreatable.
    The next day we swapped gears from 3.06 to 3.23 and dyno'd again just for the heck of it. X-~20.
    Nothing else changed and the torque curves were identical except for being up or down on the chart.
    I had heard changing gears would affect the numbers but was a little surprised that it actually seemed to do just that.
    Jan 2006
    Dallas, TX
    Dynoing in 4th gear will give a higher number as more power is going to the rollers, less to internal inertia of accelerating the components.
    As for rear gear changes, try it again in a couple months when the gears have meshed and the new bearings seated and you will have your power back.
    I have a post in the knowledge base that answers the details of this question if you need more info.
    Sean
    Largo, FL
    Your buddy is floating on a cloud... 3rd gear will show LOWER numbers than 4th. It could be that the dyno operator miscalibrated and created an artificially high number for the 3rd gear pull.
    The lower gears have higher parasitc losses.
