Results 1 to 8 of 8
    Jul 2008
    Moses Lake, WA
    EGR off and MDS on???
    I recently turned my egr off. Went back into the tune and saw that my mds was off also. I tried to turn the mds back on but nothing happened. Is there any way to have your egr valve off and your mds on?
    JBA shorty, JBA catless mids, zoomers, AFE stage 2, 85 CNC TB, HHP/BES stage 2 cam, HHP/BES ported polished milled heads, manley pushrods, titanium retainers, PSI springs, 6.1L lifters, taylor shorties, BT catch can, Diablo Tuner with a custom tune, Variant 2 coilovers, SES upper and lower grille, de-badged and de molded, BT skull insert,
    Oct 2008
    Billings, Montana
    Yeah I have my MDS enabled and have the BT egr block with the egr shut off via predator as well.
    Jul 2008
    Moses Lake, WA
    so on the predator when you adjust parameters next the adjustment there is a *. All my adjustments example o2 sensor idle egr all have * as well as my mds. When I open the mds it is highlighted as on, but I guess it having the * next to it makes me wonder if it is off. Does anyone have their mds on with an * next to it on the parameter page?
    Mar 2009
    Edmonds, WA
    When you turn EGR off, it will make MDS turn off. Once you go under MDS and click on, it will be on. The asterisk is there to show that you switched something-which is ON or OFF when you picked the EGR off. Hope that isn't confusing. As long as you select MDS on, it will be on. When you load a tune, MDS will take a few miles to come on-it isn't instant after a new tune install for some reason.
    Tucson, AZ
    Yes, like gdragich said. Once you turn off EGR you have to go back and specifically turn MDS on. If you do nothing then turning off EGR will also turn off MDS for some reason.
    Nov 2005
    New York
    hmmm...thanks for the info boys...gotta check that now
    RIP
    12.869 @ 102.02 Stock 5.7 w/ C&L, Predator, JBA Cats, Volant catback, 3.06 Getrag, DRs & skinnies www.hemirace.com
    Currently 12.26 @ 111+MPH with a completely Stock 6.1 4,250 lbs.
    Jul 2008
    Moses Lake, WA
    Quote Originally Posted by Gdragich View Post
    nope, you speakin my language
    Feb 2007
    Michigan
    Yep, it is possible to run MDS with no EGR. When you turn EGR off, it turns MDS off too, so you have to go back and turn it back on. Nothing is hurt by this, just the way the software works. Most who turn off EGR dont run MDS, so it just does it in one shot.
    Mike
    06 Magnum R/T Midnight Blue
    Inertia Motorsports Heads decked .030 (10.3 CR), FRI Hellfire cam, AirHammer, JBA Headers, JBA Mids, JBA Cat-back, Diablo Predator, 6.1 Injectors and rails, ZEX N2O Kit, Nitrous Outlet N2O plate,180* T-Stat, DashHawk, Police Package oil cooler
    11.89 @ 116.94, 1.99 60', stock converter and tires http://i162.photobucket.com/albums/t...m/SCAN0007.jpg
