Results 1 to 6 of 6
    gonzo's Avatar
    gonzo is offline you know what they say about magnums....
    Sep 2009
    new westminster b.c.
    Electric Throttle Control...is it covered under warranty?
    So my magnum seems to be broken. The light for the Electric Throttle Control is on....and flashing(which, according to my manual is a bad thing....No s**t sherlock). I'm wondering if this sort of thing is covered under warranty? or if it's gonna be out of my pocket?
    Anyone else have this problem before? It's not a good one to have. You pretty much have a non-existant gas pedal. Speeding......Not any more!!!! Can barely get upto speed now. Thanks one and all.
    '06 Magnum AWD. CAI, 22" KMC Slide wheels (black), Grill Master 5 piece black grill, Eibach Pro lowering kit (1.5" drop), JVC in-dash DVD, Art of Noise Audio Dual sub enclosures. 2 10" JL subs, JL G1700 Mono Block, LSD "Lambo" door hinges.
    Dec 2008
    If you still have warranty it should be covered.
    gonzo's Avatar
    Sep 2009
    Quote Originally Posted by In HEM I Trust View Post
    I have tons of warranty.
    In A Bunker......
    Make sure you check up on the warranty......I had extended warranty and all it covered was powertrain..........Electrical parts have only a 1 year Warranty IIRC...............Check the plugs for the throttle body.......they may have just worked loose.....
    But I happen to have a spare Ported and polished throttle body kicking around the shop if your throttle body is the problem....
    2007 Silver Metallic Dodge Charger SRT8............The REAPER
    HEMI Registry #1575.......PB - 13.390 @ 106.67 Mph.
    Proud Member of The WTFDTSG Club.........
    Jun 2009
    West Kelowna, BC
    Quote Originally Posted by SKULLBOY View Post
    I got three years, 100 000 kms for everything when I bought mine, so hopefully yours is the same. Good luck man!
    20" Dip wheels, Mopar '10 Dual Exhaust, aFe Stage 2 CAI, Eibach Pro-kit, Alpine Type E 12.
    gonzo's Avatar
    Sep 2009
    I may change it even if it's not the problem. Where would I find the plugs for the throttle body? I'm thinkin that might be the case. This has happened twice now. Today and about a month ago. I can't help but think that if this was a serious situation it would be a constant problem.....I hope. Hopefully things are just lose.
