    Jan 2010
    Pomona, Ca
    Tach and temp gauge quit working
    What up guys and gals,
    I was drving home today and looked down and noticed that the tach wasn't working. And, the temp gauge was at not working as well.
    There is a clicking grinding noise behind the gauges when the ignition is off?
    Has anyone experienced this?
    Thanks for looking.
    Jes
    Jan 2007
    LongIsland N.Y
    NO have not had this but try this hold down the black push pin that allows you to select
    the miles,trip, temp and turn the ignition to the run/on position.
    Don't start the car it should do its own cluster test see if this gets
    um moving.Also cycle the key on off on off on see if a code comes up
    and write it down.after that try pulling fuse 11 and reinstall it while car is off.
    see if this helps don't know if will but it is a shot.
    Stock 2016 GO MANGO Charger R/T 8 speed.
    K&N drop in Air Filter,Tints,Tail light tints
    Jan 2010
    Pomona, Ca
    After all my gauges went out (could live without the fuel gauges). I found a shop in Anaheim called ProSpeedo. They fixed my gauges for $250. It beats paying 600 bucks for a cluster and programing at the dealer. You can google prospeedo and it comes right up.
    Thanks for the suggestion Running Bull. But that didnt work.
Tags for this Thread
