Results 1 to 15 of 26
    Mar 2006
    San Marcos, CA
    Short Runner Valve binding... repairable?
    I tripped a P1004 code at 65K miles which is the Short Runner Valve issue that has been covered by TSB 18-003-07. I removed the actuator and the valve rotates as it should but I think it is binding and probably the reason the code triggered. I sprayed some lubricant in there, put it back together and cleared the code but I think I am in for a repeat. Question... when the intake is removed can it be opened up to get at the Short runner valve or is it sealed. I bet some cleaning and lubrication would fix it if the intake can be opened up. Suggestions appreciated.
    Thanks
    2006 300 Limited
    22" Forge-Tec FT15's
    265/35/22 Dunlop Direzza DZ101
    Eibach/Mopar Lowering Springs
    Eibach Struts and Shocks
    Precision Mesh Grille
    Mopar Dual Cat Back
    Predator Tune
    AirRaid CAI
    greasy cardboard box
    upper intake plenum is sealed. once they start sticking, we just replace them. never tried to free one up.
    Mar 2006
    San Marcos, CA
    Thanks I am out of warranty and I am sure that is a very pricey part... any suggestions as to repair. Has anyone ever opened one up to see what is causing the sticking problem.
    NC Coast
    Plenum - 3.5 liter - 3.5 liter 2006 $285.00 $213.75
    WWW.DodgeMagnumGrille.com
    Quality.....Service.....Satisfaction
    Makers of the "Original Honeycomb" & "True SRT" grilles for your SE,SXT or RT. Custom made grilles for your SRT Magnum also.
    Mar 2006
    San Marcos, CA
    The parts guy at my dealer today quoted me 1500 dollars... what is wrong here?
    Nov 2005
    Phoenix, AZ
    Quote Originally Posted by SoCalHarley View Post
    You used the word "dealer".
    Mar 2006
    San Marcos, CA
    Quote Originally Posted by NC-SXT View Post
    Where can I get the upper plenum for this price? Thanks
    plenum is no longer available on it's own. it now comes preassembled with SRV & MTV actuators, MAP sensor and throttle body.
    upper intake plenum assembly:
    P/N 04591863AH $385.00 cad. supercedes to P/N 68036667AB $2050.00 cad.
    i'd be getting TSB 18-003-07A done before condemning the plenum. those valves are not as smooth as you might think they should be. the flash may be enough to prevent this DTC from recurring.
    Jan 2008
    LX & LC Nation, Brampton, Ontario
    Holy $$$$$$$ pricey chkn,yikes...
    06 SXT AWD Magnum, Silver Steele Metallic: Chrysler's Red headed stepchild!!!
    I drive mine like I just left the bank after an unapproved forced permanent loan ...
    Mar 2006
    San Marcos, CA
    How customer friendly is that.... I gess that was what I was being quoted on.
    Another question... if the actuator was not able to action the valve properly due to bind would that automatically trigger the code. So... if there is no code does that mean the valve IS opening and closing properly.
    Thanks
    Phoenix, AZ
    Check ebay
    Starting over with a new Magnum RT (SRT8 Conversion)... 6.1L with SRT Max Cam, Corsa catback with chambered center pipes, Sinister Extreme dual ram intake system, SRT Suspension, silver Brembos, graphite powder coated Charger SRT wheels, frost white intake manifold (ported) and valve covers, matte black engine bay, carbon fiber engine accents, 300C SRT8 Front end, Matte White vinyl wrap, Black Ops 300-Challenger style carbon fiber hood. Project "SnoMachine" all work performed by Arizona Hemi Specialists - Plum Floored Creations, Mopar Automotive Photography
    if there is no code, the system should be working properly.
    if there is a code, the valve may or may not be sticking. that's why the TSB gets you to flash the PCM first. IIRC, this flash changes the fail criteria.
    P.G. B.C. Canada
    My runner is noisy. I can hear it "click" open when I give the motor some pedal. Done this since I owned it day one and never a problem.
    Spokane, WA
    That's pretty pricey for the plenum. You'd almost be better off looking in a junk yard for one.
    Mods: Big Bully/Spectre Cold Air Intake; R/T Exhaust;JDM Headlights; SRT Sways; Tinted Windows;Boston Accoustic Speakers and 10" sub, Crunch 500 watt power amp; KW V1 Suspension/Coilovers; Predator Tune; Fog Lights; 71mm TB and lower intake; HoneyComb grille; JBA Headers.
    Mar 2006
    San Marcos, CA
    So no code means it is working OK.... I will see if it triggers another code. The valve does rotate but takes some effort. From the size of the accuator I guess they must have a bit of torque to them. I guess it must be working now. Thanks
