Results 1 to 15 of 28
    Nov 2007
    Sumter, SC/ currently Iraq
    Why does Auto Trans Fluid level rise when Hot
    Im curious as to why automatic transmission oil rises on dip stick when hot..
    Engine oil, diff oil ect do not rise....Im sure its not the oil expanding when hot that makes it rise on the stick....
    Can anyone explain to me why this happens...I googled it and didnt find the answer..
    Thanks in advance
    Rick
    My Name is Rick
    Cars Name is Alice
    SEE SIG ABOVE plus....Lots of BT goodies inside - Lots of custom aluminum inside, Factory REC Nav
    AAC HID fog lights - LED smoked tail lights...with LED bulbs - LED everywhere inside and out
    More to come, Im a broke A$$
    Apr 2009
    Central Utah
    I can't think of anything other than heat expansion. Same happens with coolant. And yes, the same does happen with engine oil.
    P.G. B.C. Canada
    Quote Originally Posted by rickf28 View Post
    Thanks in advance
    Rick
    Youre not serious right?
    Yes..heat expansion happens to all running gear vital fluids.
    Nov 2007
    Ya im serious.....Im sure all fluids expand to some degree when heated.....but my engine oil doeasnt have a hot and cold check level, nore does the diff...and manual transmissions can be checked hot or cold, so im guessing there isnt much expansion going on there .......The coolant does have hot cold and so do most power steering.....(thinner fluids maybey) but the are" your not serious comment "answers nothing that I asked...But then again I have noticed that there are lots of people on lxforums lately that act this way....to bad I guess...this use to be a friendly helpful place to gain knowlage
    The reason I asked is because i was curious if the fluid expanded that much..(quite a bit of difference in trans hot and cold levels) or if it has to do with the way an auto trans works.....
    Ive asked several mechanics and they all have different reasons...some say bands and clutches swell when heated ect...I just thought there was more to it then heat...thats a lot of expansion...
    But if thats all it is then maybe it was bad question...Ive just never gotten a strait answer on this one....
    May 2006
    South Florida
    I think perhaps the thermal expansion issue is more evident in trannies because of the volume of fluid involved (roughly 3 gallons) and the fact that the dipstick enters the tranny at a place where only a small portion of the fluid pools (the pan as opposed to all the lines and especially the torque converter).
    I think you end up with something similar to the tidal effect, which is exaggerated in many parts of the world due to the structure, shape and length of the body of water open to the sea and other complex shorline and ocean bottom features (nothing to do with the gravitational pull of the moon and sun, which are cyclical mathematical constants).
    How's that for a guess?
    Oct 2004
    LaFargeville, NY
    Why it rises is irrelevant, it does and is documented.
    05 Magnum RT 5.7 (Member ALLPAR.com 200,000 mile club) Rockinsrt8 shifter, Hemi reg #164 325,000 miles
    Sidewinder, 6.1 pushrods, springs, underdrive pulley, SRT exhaust (donated by NHDave) headers to tips, all installed by Hemi31! Quaife, certain Pedders bushes installed, SRT Nivomats and Bilsteins. Police rotors and pads. HIR. Predator. LMI.
    09 Jeep GC Limited, Hemi powered of course.
    1:19 NJMP Lightning
    1:45 Mosport
    May 2006
    South Florida
    Come on now, BigJim...it's an interesting puzzle.
    Personally, I think that if a transmission were 3" deep, 3' wide and 6' long, you wouldn't be able to detect thermal expansion of the fluid on a dipstick.
    So there.
    Lorain Oh
    Quote Originally Posted by lou1355 View Post
    So there.
    x2
    BFNY Performance
    440-787-7235 8am- 5pm
    BFNYPERFORMANCE@YAHOO.COM
    RIP NHDave
    RIP LOU1355
    greasy cardboard box
    pretty much everything expands when heated (metals and fluids). the rate of expansion, and, as Lou pointed out, the shape of the reservoir, will dictate the amount of level rise. automatic transmissions are especially susceptible to level rise because the valve body takes up most of the room inside the pan. so, any any expansion will result in a noticeable increase in level. the reason fluid level is so critical in an automatic transmission is because if the fluid expands to the point where the rotating components can churn up the fluid and aerate it, pressures will become unstable.
    May 2006
    South Florida
    Well, we sure as hell don't want any of that!
    Unstable "pressures" you say? I think there is a lot of that going on in my particular hot rod.
    I'm going to have to look into that.
    Nov 2007
    thanks...this is more what i was looking for
    Nov 2007
    Quote Originally Posted by bigjim View Post
    we all know it rises...I just wanted to know why
    Nov 2007
    Thanks for the info
    Charlotte, NC
    Very interesting read.
    The Old
    The New:
    Center of the LX Universe
    Don't forget... It's not just the fluid that's expanding, but the solid materials inside the transmission that expand with heat too.
    When temperature increases, so does the length of the molecular bonds. As a result, solids typically expand in response to heating and contract on cooling; this dimensional response to temperature change is expressed by its coefficient of thermal expansion (CTE).
    Different coefficients of thermal expansion can be defined for a substance depending on whether the expansion is measured by:
    • linear thermal expansion (CLTE)
    • area thermal expansion
    • volumetric thermal expansion.
    These characteristics are closely related. The volumetric thermal expansion coefficient can be defined for both liquids and solids. The linear thermal expansion can only be defined for solids, and is common in engineering applications.
    2005 AWD Magnum RT. FRI Econo Heads & FRI Sidewinder, JBA Shorties, JBA/HHP hi-flow catted mids, stock SRT8 cat-back, C&L CAI. 12.645@108.18 - RETIRED
    2015 Chrysler 300S - Daily Driver
