Results 1 to 15 of 17
    Long Island, NY
    beeping sound??????
    VERY wierd sound coming from my car after every stop, only whe the car has been driving for a half hour or so.. When i first heard it i looked at my front wheel and notice there was a loose lug, tightened it up and was coolio.. then today and yesterday ive been doing a bit of driving, and it started again.. it sounds like a car alarm being setting like a "beep=beep" but VERY VERY LOW- if the radio is on i cant hear it, but once ihear it i cant get it off my mind, tryinh to figure it out.. it happens IMMEDIATELY after braking, sometime it will do it when going into reverse..
    Anyone have any ideas??? also notice that when I am driving in stop and go traffic, i get a click after hitting the brake, feels like the click is tight under my seat...
    Jan 2008
    San Antonio,Tx
    I've heard it too at cruising speeds
    The Boss : Vortec Supercharged 3.5 V6 AE Carbon ported lower intake and TB! too many mods to list just have to see it person.Member ACLX Club as you can see we don't play around out here.!Update! Soon to be loaded with Inertia Racing Heads and Cams! !New Dual Sunroofs! (check out my post)
    Long Island, NY
    i never hear at cruising.. only after braking - sometimes at take off, but when i hear it at take off it is actually a different sound pattern, but the same pitch..
    Long Island, NY
    OK -So I am definitely not crazy with this sound... stioll happening..
    but this morning- i noticed something else with it..
    go in reverse it makes the sound, then go back into drive it does it again...
    could it be a brake issue?? tranny issue? diff issue???
    Jul 2007
    Medicine Hat, Alberta
    You said you found a loose wheel lug nut - correct? If so I'd be taking the wheel off and checking the mounting holes to see if they are worn, also retorque all the other wheels and if you find any loose take those off too and inspect. If it has a warranty on it take it in.
    By chance were the wheels off at some time recently - if so I'd be going back to who did it and having them check everything over at thier cost and repair/replace anything that is not normal.
    Long Island, NY
    last time the wheels were off was early august.. me and the guy at the shop didnt leave off on the best terms last time I was there, so I was hoping NOT to go back to him.. but i guess if I have to - I have to..
    Long Island, NY
    just made an appointment with the dealer.. with a technician road test..
    Jan 2008
    San Antonio,Tx
    does it sound like its coming from under the dash?
    Long Island, NY
    absolutely not- it sounds like its coming from the back of the car..
    Jan 2008
    San Antonio,Tx
    mine sounds like its under the dash
    Long Island, NY
    just shooting the breeze with a mechanic tonight, he said that it could be an axle bearing?????
    greasy cardboard box
    Long Island, NY
    possibly-- Thank you so much for that- it sounds like it may be the problem!!
    Jan 2008
    San Antonio,Tx
    fnkychkn what could be beeping at cruising speeds be its on the drive side right by the door
    Quote Originally Posted by leveil22 View Post
    sorry, can't say i've ever heard of that one.
