Results 1 to 15 of 19
    Aug 2007
    Dallas, TX
    Melling Oil Pump Pressure
    Straight from the box:
    "Important Pressure Relief Valve Spring Requirements
    Use the optional purple (65psi) pressure relief spring for 6.1L Hemi Engines.
    The installed Yellow (50psi) relief spring is the stock springs for use with 5.7L Hemi engines".
    I read that as the Melling Oil Pump does supply an increase in pressure if you use the optional purple springs for 65psi where the stock spring is only 50psi.
    Nov 2007
    Certified liberal hater
    Only used the purple spring so I'm sorry to say not sure what happens with the others. Ultimate goal for me is a dry sump or a different pump, different oil weight all together.
    I'll keep my money, guns, and freedom, you can keep the change.
    Lorain Oh
    I don't think Melling is realizing that a modded 5.7 revs to 6400 just like a 6.1. I would use the purple spring.
    BFNY Performance
    440-787-7235 8am- 5pm
    BFNYPERFORMANCE@YAHOO.COM
    RIP NHDave
    RIP LOU1355
    Nov 2005
    Romeoville, IL
    Or the added pressure is for the oil squirters...
    Lorain Oh
    Quote Originally Posted by GasGunR View Post
    Just went through this on a stock 5.7 pump......53psi max pressure at 6500 rpm.....that don't fly with me.Now there is a 6.1 pump making 68 psi at 6500 rpm......much better.
    The SRT engine squirts oil to the bottom of the pistons for cooling and maybe that is why it needs more pressure. The higher the pressure, the more hp it takes to run the pump.
    Lorain Oh
    Quote Originally Posted by 2005rtmag View Post
    Yes I know......I also know that 10psi per 1k rpm is a happy place on a high revving motor.......but do you think it could be the fact that a stock 5.7 shifts at 5800rpm and a 6.1 shifts at 6200?
    Nov 2005
    Romeoville, IL
    I remember when anything over 60 would foam your oil We're in a better place these days
    Nov 2007
    Pressure is the opposite of flow (or due to the lack of flow) Flow is whats important. Pressure also creates heat.
    Feb 2006
    New Orleans
    Quote Originally Posted by Maistro69 View Post
    ^^^^What he said ^^^^
    SOUTHERN HOTROD, LLC
    2230 Richland St.
    Kenner, LA 70062
    SOUTHERNHOTROD.com
    888-BIG-HEMI
    Home of WAR VIKING Transmissions!
    www.WARVIKINGTRANSMISSIONS.com
    NAG1 and 8HP
    Mar 2008
    Stamford, CT
    X2. I going with the Melling to get more volume of oil. Ideally, I want the most oil volume at the least amount of pressure.
    Lorain Oh
    so do parts not getting enough lubrication......yes I know flow is important too......but with the way our valvetrains feed I'd like both thank you.
    Lorain Oh
    Quote Originally Posted by richierevs View Post
    And as long as thats not below the stock 65psi I agree.
    Feb 2004
    Seattle, WA
    given the *exact same* engine (swapping pumps and keeping the same oil weight), a higher pressure reading on the oil galley means that you actually are getting more flow.
    Increasing viscosity to get more pressure reduces flow.
    From everything that i have seen.. the Melling is just a stock replacment, no? The e-mail i got back from them said they don't have any increased flow setups yet....
    2012 Ram 1500 Express - 4x4 - HEMI - Black
    1966 Dodge Charger - ???? - ????
    Experience is that marvelous thing that enables you to recognize a mistake when you make it again - Franklin P. Jones
    Insanity: doing the same thing over and over again and expecting different results. - Albert Einstein
    Nov 2005
    Romeoville, IL
    Yep, pressure and flow are realated, and with a given pump, more pressure will mean less flow... so if you've got .015" clearance in all your bearing journals, you'll have plenty of flow and very little pressure. The engine though, won't stay together at 6000 rpms.
    I'm with Erik, I want both Still I'm not convinced that anything over 60 - 65 psig matters much for us.
