Results 1 to 12 of 12
    Nov 2005
    New Jersey
    Hot start, Long crank
    I have a 2005 Dodge magnum rt 12/04 build date, kn drop in filter, cat back exhaust.
    My problem is that if I try to start the car when hot it cranks for about 45-60 seconds then starts and runs fine. I have installed a new fuel pump thinking that was my problem with no success. I think that maybe there is a temperature sensor that might be going bad any advice would be appreciated.
    Dec 2008
    Beaverton, Or
    Bad fuel filter?
    Maybe the ECM is going bad and the heat makes it not work? Heat and circuit boards don't do very well together.
    Oh, and don't crank the car for 45 seconds straight. You'll burn up the starter.
    BOUGHT 11/6/14: #42 2008 BB MSRT8 67K, Option Group I,II,III, roof rack, factory HID's, SRT Design factory rims, Rear VES, Sirius Backseat TV. AirRaid Ram Air, Magnaflow exhaust, DS Intune, Motorad 180 T-stat, BT Catch Can, KW Variant2 coilovers. Current dyno at 378/378
    SOLD:
    Early Build 2005 CV Magnum RT, DS Predator, Jet 180, K&N Type 57 Cold-air, Eagle Eye Dual CCFL Halo Projectors w/ LED turn signals, 55W 6000K HID low-beams, SRT exhaust, SRT Rims
    Nov 2005
    New Jersey
    There are no fuel filters on these cars they have a strainer on the bottom of the fuel pump
    Dec 2006
    Upstate, New York
    I have had the same issue from time to time. I find it minor issue, as long as it starts. So far so good.
    "Heimes Oppugnamus Et Montes Superamus"
    Nov 2005
    New Jersey
    Yeah I myself don't care that much but the wife drives the car mostly now and she is afraid it might not start one time and with no check engine light the stealership wants $ 90 just to look at it even if those idiots at my dealership can't find a problem
    May 2006
    New Orleans
    I remembering reading about this somewhere. I believe the crank or cam sensor was the culprit. Please correct me if I'm wrong.
    05 RT . Jett Black . SRT Fascias . UAS . AFEII . Zoomers . Forgiatos . Wilwoods ...
    Thanks Surfer1420 thanked for this post
    Mar 2009
    montreal.qc.ca
    mine does that also quite often ...quite anoying when near friends. after 15 seconds everyone turns around and give you the hummm looks !
    once dint start ...i had to lock doors ,delock doors then start again .....go figure !
    protouring 84 cutlass: 450hp LT1+ 700R4 +9.5" t/c 3200rpm + ford 9" ,4 wheels disc brakes ,lowered 2" ,4 link , tubular A arms .....
    CJ7 jeep,4.0L 250HP, AX-15,dana 300 +tera lo, soa , 36 iroks, dana 44`s,4:10 ,auburn ected,s ..
    and finally a "cool vanilla" AWD RT magnum .
    Should have SRT heads, intake & exhaust soon!
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by gameover View Post
    Yezz sir, the crank postion sensor. Good call bud
    They run under 30 bucks and it's located on the passenger side behind the starter. You'll need to remove the starter to install it ( well it's 10X easier if you do ). If your handy with tools, it'll take you 20 minutes to change.
    From wild to extra wild we got you covered with crap ya never knew you needed.
    08 route 66 burnout champion 07 Shindig 6.1NA winner. Willow Springs 1:42!!. 11.796 @ 117mph
    Apple Valley, CA
    I've had this on this car and others, its not so much that the sensor is bad just how its "timed" sometimes. THe cam and crank sensors work together, working of timed refrences usually. Just sometimes when the motor is shut off the slot that the sensor uses for a reference is sometimes just a lil off from where it likes to be. So the car sometimes had to crank longer to get "re-referenced" so the proper timing positions line up, the sensor become synced and the car starts. Just sumtin that happens now and then. Usually not a big deal.
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by gr8crash View Post
    Very good point. It could be your cam chain tensioner is wore out too.
    Jul 2009
    florida
    heyyy could be the tstat or maybe even the radiator cap mineee went bad and i was having engine shaking problems and it was saying that my car was overheating but it was just the hot air evaporating my coolant try and pressure test it??!! andd it ran fine when it was cool out only had problems when it was hott out
    Nov 2005
    Romeoville, IL
    My motor did this when the cam position sensor failed... replaced it and good to go!
