Results 1 to 10 of 10
    Jun 2007
    Ottawa, Ontario, Canada
    P5155235 Mopar long tubes for 6.1 on 5.7?
    Anyone know if I can fit these on my 2006 5.7? I think I need to use SRT cats (I think they are part of the package). Question is will they bolt up to the 5.7 heads?
    Black Bullet
    Apr 2006
    Huntersville, NC
    Those headers come with catless midpipes. They won't just bolt up to stock SRT cats.....
    Stock 5.7
    Jun 2007
    Quote Originally Posted by MadCharger View Post
    So I would have to add some hi-flow cats? I can do that - I'm hoping to get them for a good price. Real question is on the head/port fitment
    Apr 2006
    Huntersville, NC
    Quote Originally Posted by Black Bullet View Post
    They'll fit the same as the stock SRT headers fit the 5.7. I believe you'll need to disable EGR via the Predator though (but I could be wrong). Maybe not, since those headers are also for '09 R/T's.
    Jun 2008
    Lake Grove, NY
    they'll bolt right up, use 6.1 gaskets, disable the EGR or groove the header if you want to keep the EGR system.
    http://www.lxforums.com/board/signaturepics/sigpic23029_3.gif
    MY HEMI REGISTRY PAGE
    Quote Originally Posted by MattRobertson View Post
    ... Do it for fun and enjoy the improved performance, but don't think you made a transaction that makes any financial sense. Use the economy numbers to torpedo the tree hugger who wants to get snooty with you, but know in your heart you did it so you could go faster.
    Jun 2007
    Quote Originally Posted by gooeytek View Post
    What does that mean ^^^?
    Seems like this is doable, I do have a predator, now have to work on the price of the LT's...
    Jun 2008
    Lake Grove, NY
    the EGR works by diverting a bit of the exhaust back into the intake via a small tube from the #2 exhaust runner (frontmost pipe on passenger side). a quick and easy way to simulate this is by making a groove that runs from the edge of the #2 cylinder runner about 3/4" long, enough to reach the EGR port on the head.
    like so:
    pic is upside down, the groove runs from the port to the front of the engine.
    or, if disabling EGR is an option, remove the EGR system & tube, and use BT's EGR block-off kit & disable the system via predator.
    edit: see that drawn circle at the end of the groove? on the 5.7 manifold, there is a hole there that connects to the runner and matches up with the port on the head to recirculate some of the exhaust back into the intake. The groove acts as a channel for the exhaust, in lieu of the tube. you'll have to modify the 6.1 gasket to accomodate this groove as well.
    edit#2: use 6.1 header bolts as well.
    Jun 2007
    like so:
    Thank you man! I love this forum, this is great info. Looks like green light to negotiate price...
    I know I can disable EGR, but that may cause emissions problems when checked? So if I groove the header I can retain all OEM systems..
    I suppose a dremel would not be tough enough to make this groove. Likely have the installer do it?
    Apr 2006
    Huntersville, NC
    If your state/county does OBDII emissions checks, then you'll have no problem disabling with the Predator. I did mine, and it didn't show up at all as disabled during the inspection. And mine is completely gone.....
    Feb 2012
    I was wondering the same thing about these headers. I have a new set of P5155235 with the catless mid pipes for sale. They are for a 2010 challenger but wondered what other vehicles andthey work on and what engine.
