Results 1 to 9 of 9
    Dec 2008
    esp bas light on..rough start and idle
    esp bas, red lighting bolt light indicator light came on the dash board aslo have a rough start and rough idle but sometimes i get lucky it starts up fine... tried codes, no codes found..friend said it might be the (ETC) or the (EGR Valve), so i bought them both and had them replaced.. WRONG! car still runs like crud!! i luv my car!!plz help!!
    Thanks!
    300dan
    Jan 2009
    I have a 2006 Dodge Magnum and I have been having the same problem since the beginning of October. The engine light, the electronic throttle light, and the esp/bas light comes on it rough idles then we stall. The dealership has replaced so many parts and still nothing is solving the problem.
    Apr 2006
    milwaukie,or
    i've had this problem get your crank sensor checked
    Mar 2006
    Mid-West Michigan
    Crank and cam position sensors have been discovered to be a possible culprit to this problem in another thread.
    The "Un"Club!
    We have two rules, Love Cars and Have Fun!
    Michigan Charter Founder
    2005 Inferno Red (PEL) Magnum R/T - Hemi Registry #000573
    - Todd -
    Aurora, IL
    Quote Originally Posted by MrMopar View Post
    on the 3.5???
    I DRINK ROYAL PURPLE! WHAT NOW?!
    > 2006 Silver SRT-8 magnum, adopted 9/9/06 with 36 miles, groups I, II, &III.
    * tinted LED Tails * Mopar Remote Start * Stainless Airhammer * Coated Kooks Longtubes * PPP Heads, Cam, and Converter * Alpine R10 Subs/AoN Enclosures * 20" Black AR 311's w/ Nitto 420's * Corsa cat-back * Front Window Tint * Ratman Hatch Button Mod * Hotchkis Sways * BT Underhood Bling * Polished Intake Manifold * Autodim Drivers Mirror *
    Feb 2007
    Harrisburg, PA
    I'm having a similar problem. I'm taking it the dealership next week. One of the codes I received is P061A. I was told that it could possibly be the PCM that would need to be replaced and that it should be under warranty since I'm under 80K miles. My car is to the point now where I don't drive it much because it stalls and stops so much. I will keep you all posted.
    Apr 2009
    Manitoba Canada
    Check for vacuum leaks this happened to me I had changed the spark plugs on my 3.5 after this it started to do this and I found it was the O ring on the egr tube on the back of the intake. I changed the 8 dollar O ring and haven't had a problem since. And for the P061a code I had the same one it is a throttle code its getting more air then the throttlebody is letting in.
    Nov 2005
    Romeoville, IL
    Sounds like a vacuum leak.
    SW FL
    I had this on my 05 Mag RT. I took it to the dealer (right before the 36k warrenty expired). They did NOT believe me until I kept starting it until it did it, and then the advisor verified. They ended up "flashing" the pcm and it has NOT done it since (96k now)
