Results 1 to 13 of 13
    Jan 2007
    Huntersville, NC
    Question Lights Pulse or Fluctuate
    I have a 2005 Magnum SXT. Every morning when I leave for work & I have my headlights on, they appear to be pulsing. My interior lights also pulse or fluctuate. My car is out of warranty so I have no intentions of taking it to the dealership. Does this happen with anyone else's LX? Is it an alternator issue or battery? Both are still original on my car & I have 51K on it. Any help would be greatly appreciated. Thanks.
    Frost Bite USA
    Do a search of the site, this is a fairly common problem. I am not aware of any fix for it yet.
    Quote Originally Posted by Bandit View Post
    I have been pulled over MANY, MANY times.
    SURPRISE, SURPRISE!!
    Aug 2004
    Rochester, NY
    Do they do it all the time or only when at idle?
    2005 Cool Vanilla Magnum RT (Mopar CAI)
    Jan 2007
    Huntersville, NC
    They do it all the time. Idling, driving, whenever. It does not seem to have anything to do with the radio because they keep doing it when I turn it off. It is very annoying.
    I have searched but can not find anything. maybe I am using the wrong search words.
    Apr 2006
    Acworth, GA
    It's a body module flash to an updated software. Dealer fix.
    Usually does it for the first 5 or so minutes after starting, then it smooths out when you're driving. Usually.
    Mine got fixed first time at the dealer. SXTs had a TSB.
    edit: TSB 18-003-05
    http://modsfaceoff.com/2005_dodge_ma.../18-003-05.pdf
    SUBJECT:
    Flash: Headlights Fluctuation and/or Interior Lamps Fluctuation
    OVERVIEW:
    This bulletin involves selectively erasing and reprogramming the Powertrain Control
    Module (PCM) with new software.
    MODELS:
    2005 (LX) Chrysler 300/Magnum
    NOTE: This bulletin applies to vehicles equipped with a 2.7L or 3.5L engine (sales
    code EER or EGG) that were built between June 28, 2004 (MDH 0628XX) and
    January 8 XX, 2005 (MDH 0108XX).
    SYMPTOM/CONDITION:
    The vehicle operator may experience headlight fluctuation and/or interior lamp fluctuation.
    This condition will occur after a cold start, while the vehicle is idling, under heavy electrical
    load and a slight throttle tip-in. This condition could also be described as the headlights
    and/or interior lamps changing intensity at a steady rate. DTC P0563 - Battery Voltage
    High may also be stored in the PCM.
    DIAGNOSIS:
    Using a Scan Tool (StarSCAN) with the appropriate diagnostic procedures on
    TechCONNECT, verify all engine systems are functioning as designed. If DTCs are
    present other then the one listed above, record them on the repair order and repair as
    necessary before proceeding further with this bulletin.
    If the customer describes the Symptom/Condition, perform the Repair Procedure.
    Tucson, AZ
    I had that TSB done on my 2005 Magnum SXT. Problem solved.
    Jan 2007
    Huntersville, NC
    Thanks Invader. Looks like I have 2 TSBs to take over to the dealer. Wonder how much this will set me back. Oh well.
    Feb 2006
    Stockholm, Sweden
    I have an 05' Magnum RT and i got the same problem. :/
    Is there any TSB for my car on this?
    Oct 2010
    I've got the same problem but I got to ask, what do the acronyms stand for? TSB, DTC?
    greasy cardboard box
    Quote Originally Posted by Michael Methot View Post
    TSB = Technical Service Bulletin
    DTC = Diagnostic Trouble Code
    Acronyms Decrypted.
    Oct 2005
    west deptford nj
    Quote Originally Posted by Invader View Post
    edit: TSB 18-003-05
    SUBJECT:
    OVERVIEW:
    MODELS:
    SYMPTOM/CONDITION:
    DIAGNOSIS:
    yup, thats it...
    i have to take mine in, it's getting bad....
    THE ORIGINAL
    http://photobucket.com/albums/c15/sugar-tj/
    there are no strangers here, just friends you haven't met yet..
    Oct 2010
    Pulsing lights
    Thanks fnkychkn. None of the dealers in the lower mainland had heard of the problem or could find a service bulleten on it. I copied your reply and sent it to those same people and the TSB's materialized. It seems when it's going to cost them money to support or fix, it's hard to get answers.
    Acronyms Decrypted.
    Feb 2007
    Ingalls, Indiana
    Yeah, it's sad to have to provide proof of service bulletin to get anything fixed... /it's the old saying "deny, deny, deny". You just gotta wonder how many people get reamed because of this???!
    Randy '06 R/t, Brill Blk with lt slate int, 6 disk cd with Elect conv grp, Conv grp II, and Prot grp; Pwr sunroof; 600w pwr inv; HW Radar Det. and phone dock; Tint Win; Tail lts Blacked out, Restraint decal, sheriff plate sticker; Danko- Chin Spoiler, 3 piece wing, Cust lit HEMI Shaker Ram air CAI system; Led- Eyebrows, back up lights, trunk overhead lights, glove box and center console lights, plate screws, back lit wheels and vents on metal fenders; 3 USB Ports; 2 Audio inputs for stereo; HID 3K with Halo Headlights.
