Page 1 of 9 123 ... LastLast
Results 1 to 15 of 126
    Mississauga
    How to install your Pink thingy (w/ pics)
    Ok boys and girls, I haven't seen one of these threads yet so I decided to take it upon myself to photo-document my BT Park Lockout install.
    For starters you will need some tools (socket set, needle nose pliers, universal screw driver, and a bottle opener) the BT Lockout, and of course some liquid refreshments.
    Step one:
    Now that you have a beverage, set your radio to a good station, now you are ready to start!
    Start by removing all the loose trim pieces (tray below ash tray, cubby beside shifter, chrome shifter trim, and the tray inside the arm rest)
    With the tray out of the centre console remove the 3 8MM bolts around the raised sheet metal
    Next remove the trim plate on the centre stack (I find it easiest to start at the top and then the bottom)
    Once it it loose there are 3 sockets to disconnect, 1st is the Hazard/Airbag/ESP socket
    Then the 2 for the Climate controls
    Next pop the ashtray panel free and disconnect the 1 or 3 harness' from it
    Now you can unscrew the 2 screws that go into the dash
    Then the 2 that go into the floor
    At this point you will be able to lift the whole centre console, there is going to be 1 or 2 harness' to disconnect before it can come out though, 1st is for the Accessory power, next if you car is VES equipped it's harness. I found it easier to recline the seat to disconnect them.
    Now we are into the nitty gritty, there are 4 10MM (Deep socket, w/ an extension are preferable here) nuts holding the shifter assembly down, 2 on the back
    and 2 on the front
    With those done remove the 8mm bolt on the passenger side that holds the shifter cable. On the drivers side unhook the lock out cable from the pink thingy. Disconnect the harness on the rear of the shifter assembly, and the unit it ready to remove from the car
    I'm not going to re-invent the wheel here so follow BT's instructional video on how to install the Lockout into the shifter assembly:
    Once the sexy new BT piece is installed simply re-assemble.
    The only thing to watch for is a set of tabs on the side aprons of the centre console where it meets the dash. They need to slip into their pockets
    And you're done!!!
    This was a 3 beer job on the difficulty scale
    Now time for a quick test drive
    AC
    http://www.lxforums.com/board/signaturepics/sigpic12069_2.gif
    'When I was arrested I was dressed in black'
    _____________________________________
    Mods: Predator 93 CAI, Air Hammer, Eagle Mani, Stainless Works Long Tubes, SRT8 diff-catback-suspension, Mopar Sways, REM Strut tower bar and Bumpsteer, Dual weave Grill, Daytona Chin and 20s, CSRT8 Diffuser, 6000K & 3500K HIDs, shaved letters, Old skool R/Ts, Hood Struts, 300C Handles & lower moldings, Two toned tails, BT Oil Catch and other goodies, and OEM remote hatch.
    13.5@105
    Thanks mlgreen thanked for this post
    Likes mlgreen liked this post
    Sep 2007
    The Great White North
    Nice
    Mods- Blastin Bobs, Airaid CAI, Mopar Remote start, Clarion DVD system, Zinik 20's, Painted splash guards, Coming soon- Zoomers, Predator
    Phoenix
    Nicely done!
    So the only cables or linkages you have to disconnect to get the unit out are the shifter cable and the spring that goes to the pink thingy?
    Nov 2007
    Lawrenceburg, KY
    What is the upside to this mod?
    *2007 Magnum R/T
    *1966 Charger 383
    MoPar or NoCar!!!!!!!
    Phoenix
    Quote Originally Posted by WGK View Post
    Here you go:
    Pink Shift Mechanism Thingy Explained - with all the links.
    Jan 2008
    Paola, KS
    Curious.. Is that a Sirius radio unit next to your Nav that has built in Sirius?
    -Matt
    "ReCoil"
    2007 Dodge Charger SRT-8 Super Bee edition
    AIRAID CAI | SLP LM Catback | Diablosport Predator | Nitto DR's
    greasy cardboard box
    nice write up. beans for you.
    disconnect battery whenever working near the ORC (occupant restraint controller/airbag control module).
    safety first!
    Aug 2004
    Ocala, Florida :-)
    Is it a good idea to put a dab of Lithium grease on the pivot point of the shifter thing that we are installing??? A light coat of grease??
    Good write up and with photos.
    Beans.
    Feb 2006
    Dublin, CA
    Beans for the write up! I'll be looking for help when I do mine.
    Member: CenCalLX & Mopar360
    "Courage in women is often mistaken for insanity."
    Twitter: Tam_aka_CG
    Instagram: cg_88
    Aug 2008
    Leesburg, Florida
    Great Job! I got mine from Scott on Saturday so now I can get
    it installed. Now that's all you need is a BT shifter plate and
    pistol grip handle
    Option Group I II III ~ Diablo Predator ~ 180 stat
    Mopar CAI ~ Magnaflow Catback Exhaust
    Sequential Turn Signal Tails ~ Lot's of BT bling
    Jina's Custom Embroidery interior mods
    FlashTech Fusion Color Halo's
    Richmond 323 Gear
    68 Danko Grille
    KillerGlass
    Ft Laud.....
    Quote Originally Posted by FloridaRT View Post
    Beans.
    Correct Bob I would add a little white lithium...
    Feb 2007
    Omaha, NE
    thanks for taking the time for this...
    -Ryan
    edit... Knowledge base too?????
    -Ryan
    Current Rides - '15 GC Altitude - White, '15 200S - Black, '93 1500 SB
    Past Rides - '05 Magnum RT - 20k SOLD
    Mississauga
    Nicely done!
    There are 1 or 2 small harness' that plug into the back of the shifter assembly, but aside from that yeah, just the linkage and the cable. The cable attaches like a hand brake on a bicycle, push it towards the rear of the car and lift it free of the pink thingy
    Quote Originally Posted by ReCoil View Post
    Lol Nav radio yes, Sirius brain not that I know of. That and it's easier to put my stiletto into my POS work van than it would be to move my REC into it
    Thanks everybody, I hope this will help w/ your pinky thingies
    AC
    Tampa, FL
    great write up! Beans to that!
    Nov 2007
    Lawrenceburg, KY
    Ahhhh....okay. Well Im still under warranty. Thanks I was just curious on what it was.
Tags for this Thread
