Results 1 to 13 of 13
    May 2005
    Ontario, Canada
    Does 5.7L Hemi have timing chain or belt?
    After searching this question on a few occasions, I've yet to come up with a difinitive answer...does the 5.7L hemi engine have a timing chain or belt?
    the 5.7 and 6.1 have chains you can see them in just about any cam install thread
    2006 Inferno Red Charger R/T|Zoomers|C&L Intake|Retro Mag 500 Wheels|Pedders Touring Plus w/ adjustable camber|General Grabber UHP 255/55/18|Flat Black Daytona Grille|BT Catch Can|SRT-8 Rear Diffuser|Mopar Chin Spoiler
    Nov 2005
    Romeoville, IL
    Chain.
    Aug 2004
    New Hampshire
    "Hey man, cool Prius!" - No One, EVER
    "It's not that I'm old - your music really does suck..."
    See The Iron Mistress Galleries
    R.I.P. Dave (nhdave) Coults ***
    *** R.I.P. Mark (MAGNUM8R) Paulson ***
    *** R.I.P. Rich (CtCruzer) Wesley ***
    Feb 2006
    sunny florida
    nope
    To my knowledge you'll never see a cam-in-block engine with a belt.
    Only overhead cam motors have this luxury, and my last toy (1970 240Z) had a chain. A very LLLLOOOONGGGG chain!
    Steve
    06 300C SRT8
    Best ET-12.794, trap 110.9 All stock in negative D/A
    http://www.youtube.com/watch?v=Ks1gplWiXvY
    Apr 2014
    Fort Lauderdale, FL
    Even some overhead cam engines have chains, some tend to have belt due to the cost factor and leave the additional maintenance to the customer. Besides how many new car drivers hit the 80k mile mark before having to change it? Not many I believe.
    But the Mercedes, 112, 113, 272, 273, 276 and 278 engines have chains. Not to mention the AMG engines 156.
    Chain is better in my opinion.
    Quote Originally Posted by stevesrt8 View Post
    Except for the Nascar engines. I've read that those engines use belts because they are more efficient, use less hp.
    Mar 2010
    Atlanta
    The Dodge 4.7L OHV engines are chain driven.
    Nov 2008
    Athens, Ohio
    when should you change it?
    Sep 2013
    Louisville, KY
    ^^X2^^ I'm at 100,000 miles, and don't want it breaking and destroying my engine like my turbo VW did!
    Feb 2015
    Quote Originally Posted by 2005rtmag View Post
    Umm, I disagree. Most NASCAR engines use a chain, for durability reasons. A belt engine requires FRC - Free Running Clearance, so that if the belt breaks, you don't punch holes in the pistons when it breaks. NASCAR engines are not using FRC with the compression they're pushing. NASCAR Engine builders need durability, even if it's for 500 miles.
    Also, you'd be surprised to know that MOST engines these days are OHC (either SOHC or DOHC) and MOST use chains. How do I know? I work for one of the largest automotive chain manufacturers in the world.
    Lastly, belts need a dry environment (although some are experimenting with wet belts) - so the belt environment needs to be isolated from engine oil, and belts durability is ~80,000 miles. Today's chains are built for the life of the engine: ~200,000 miles.
    Mar 2010
    Atlanta
    Quote Originally Posted by RDT View Post
    You won't.
    I have 344,000 on my dodge 4.7L and I've done nothing but used good synthetic oil.
    My brother has a '99 Dakota with the old 5.2L that just passed 500K miles. Chain has not been touched.
    Some will recommend changing the tensioner out as that has wear items, but likely you'll have another vehicle before you ever have chain issues.
    Mar 2010
    Atlanta
    Oh, 150K+ on my Hemi.
    Use a good oil, you won't have any chain issues nor will it need replacement.
