Results 1 to 12 of 12
    Dec 2004
    Rockford, Illinois
    Windshield Drain Hole
    My Magnum has a drain hole in the plastic shroud that is attached at the area just below the windshield and has a drain hole that routes water directly into the engine compartment.
    Went to the dealer today and he told me that this was normal, I cant believe this !!
    I noticed after washing the car that the wiring harness was all wet.
    This is the drain hole in the plastic shroud about two inches from the Wiper on the passenger side. The shroud channels the water toward the hole and it drains into the engine compartment.
    Does your Magnum drain water into the engine compartment too ?
    Nov 2004
    Orange, CA
    There are drain holes at either end of that shroud as well and a channel under the driver side wiper to let water out. Better than water shloshing around in the windshield trough.
    Attitudes are contagious. Mine might kill you.
    Lakewood, CO
    I looked and mine has it also.
    2005 Magnum SXT AWD - Inferno Red
    Mods: Diablo Predator, JBA headers, Magnaflow resonator, K & N Aircharger, KW coilovers (variant 2's), 402 Motoring tinted tails, lots of Billet Technology stuff, real walnut dash kit, MOPAR on-dash nav, NC-SXT original honeycomb grille, Jina's Embroidery custom headrests.
    Dec 2004
    Rockford, Illinois
    This design pours the water directly into the engine compartment, just above and all over a wiring harness !!
    Am I the only one that thinks this is wrong ?
    Pittsburg, KS
    I don't personally see a problem with it. Where else would the water go? We could probably adapt some hoses to it to have it drain lower if we thought it were a problem?
    Nov 2004
    Orange, CA
    Quote Originally Posted by karpins
    So far you are the only one. You could tape over it if it really bothers you.
    Jan 2005
    Here, There and Everywhere but 150 miles from nowhere
    When you drive in the rain where does all the water go when it goes into the grill? Lots of water blows through there I would imagine.
    Lead, follow, or get the hell out of the way.
    '05 MB E320 CDI Alpine White, mine 145 MPH+ & 37 MPG
    '91 MB 300D 2.5L Turbo, wife's 117 MPH & 33 MPG
    Aug 2004
    Ventura, CA
    Hmmmm, that is a fairly good observation. Wonder if adapting a drain cable to route it lower into the engine compartment would work well. That would be a good experiment !!
    Jan 2005
    State College, PA
    I haven't seen this yet but...
    I know they use a lot of really good watertight connectors but the thought of dumping water on a connector bothers me, too. There isn't probably a lot of water that gets through that hole though. I like the idea of adding a hose to carry the water below the connector.
    Jun 2004
    Hunstsville, AL.
    Most outside cabin connections are done with weatherpak sealed connectors. I have to agree that "it just aint right" to get them wet. They hose extender is cheap peace of mind..
    And the dead shall walk
    Dec 2004
    Rockford, Illinois
    Easily a gallon of water during the course of a normal car wash.
    I could see it running out from the engine compartment from under the vehicle during a wash and rinse.
    All of the water that strikes the windshield is channeled into the plastic shroud and then directed to three drain holes.
    The drain hole in the middle receives a good share of the water plus anything that the center drain cant handle is also routed into the opening for the windshield wiper shaft hole that is also directing water into the engine compartment directly adjacent to the firewall.
    The firewall, wiring harness and the top front of the tranny are all getting saturated.
    Dec 2004
    Rockford, Illinois
    I like the extender drain hose idea.
    It would need to be able to collect the water from the center drain hole and the opening in the shroud for the wiper shaft on the passenger side.
    The drain hole and the wiper shaft hole both drain water into the engine compartment.
    Collect the water from both of these sources, and then route it to the bottom with a hose.
