Results 1 to 7 of 7
    Sep 2007
    The Great White North
    7db kit installed
    Well I got my 7db kit installed finally, first off, sounds great, tips look awesome, no more ugly resonator poking out the bottom, but I cannot get the pass side lined up the same as the drivers side. The drivers side went on perfectly, centered just right. The pass side if i get it perfectly centered is way too far "in", almost behind the fascia. If i set it to stick out the same as the other side, it rubs against the side of the cut out in the fascia. for now i have them both set a little off center ( to the outside ) just so that they are even, still looks pretty good, just not as perfect as I would like. Any suggestions?
    And I know, , Ill get some if needed, and when I figure out how.
    Mar 2008
    wilmington ohio
    do you like ?????
    i am looking for new exhaust for my 05 r/t...
    any drone at highway speeds ?????
    See this thread on how to adjust. Your won't be too difficult since the tubing diameter is smaller. http://www.lxforums.com/board/showthread.php?t=114563
    Sep 2007
    Quote Originally Posted by 44REDHAWK View Post
    do you like ?????
    Ya, i like, not quite as loud as I thought it would be, but a very nice sound. And NO DRONE at all on the highway.
    Sep 2007
    Thanks Bob, how many times can the band clamps be loosened and re tightened, they seem to stretch a bit, and I dont want to ruin them.
    Sep 2007
    O.K. just finished readjusting and I think I got it right this time! Looks awesome. Went for a little cruise and am lovin the new music. Thanks for a great product Bob
    Quote Originally Posted by BlairW View Post
    Just don't over tighten them cause they will break. You should be ok to remove them multiple times, the torque spec is 23-25 ft lbs.
