Results 1 to 7 of 7
    Feb 2010
    North Alabama
    NEW Aluminum Race Blocks!
    These are not the standard Mopar aluminum blocks that were just released for the late model Hemi. These were cast 4 years ago to be used for the 24 hour of Le Mans race circuit. The program was canceled before the engines were built. These 5 blocks have unique part numbers and are the only 5 in existence. They are also numbered 001-005 from McLaren Race Engines who were the intended builders. They feature remote oil filters, reinforced engine mounts, bushed lifter bores, 65mm cam journal with roller needle bearings, billet caps with 6-bolt mains on center 3 and 4 bolt on 1 & 5. Block weight is only 88lbs. We are keeping number 1 and up for sale are 002-005. These can be built as a 376, 399, or 426. Cost is $7995 for the 399 and 426 and $7495 for the 376. In addition to the built shortblock, the customer will receive the original 5.0L rotating assembly that would have been used had they competed in the 24 hour of Le Mans. This rotating assembly consists of a Billet Crankshaft from Bryant, Carrillo Rods, and JE Pistons. There are only 5 of these in existence and they will not ever be built/sold again. Act now to get a very rare block.
    There is no warranty on this block as it is not replaceable.
    This image has been resized. Click this bar to view the full image.
    Dec 2009
    Park Hills, MO
    Very nice.
    I AM ON MIL DUTY PLEASE EMAIL SALES@EUROCHARGED.COM to contact about TCMs.
    2005 Silver Magnum R/T
    1/8 NA PB: 7.466@91.83mph 1.620 60'
    1/8 N2O PB: 6.947@96.50mph 1.539 60'
    1/4 N2O PB: 10.941@123.71mph 1.539 60'
    CT
    I'm confused. When i talked to you guys last year you said some of these things were already sold and being used in builds and only 2-3 remained. now all 5 are available again?
    Current mods: Hi-Flows, 180. Volant, PS Cooler, Trans Cooler, SS Brake Lines, B&B exhaust.
    Pedders Track II Extreme, Wavetrac, Moroso oil pan/catch can, 6.1 MTCM, Mopar trailer hitch.
    Feb 2006
    Cool
    8's N/A? Been there done that
    Jun 2010
    Glendale Heights IL
    Nice set up!
    Nov 2009
    Martinsville ,VA
    What is the bore capability of this block and how much for just a block if they are still available?
    Feb 2010
    North Alabama
    4.080 or 4.090 I think.
    I'll pm you a price on the block once i find out.
