Results 1 to 8 of 8
    Oct 2010
    Alabama
    Twin Turbo 419 final details!
    We decided to start a new thread since the direction has changed so many times in the last year regarding this car. I will start with the bottom end.
    6.1 Block
    Manley 4.05" Crank
    Manley Pro-Series I-Beam Rods
    ARP 2000 Rod Bolts
    Manley 8.5:1 CR
    Chromoly Wrist Pins
    Total Seal Steel Rings
    Stock Caps and main bolts
    Clevite main/rod bearings
    A1 Technologies Head Studs
    Manley double roller timing chain with torrington bearing
    Cometic Phuzion Head Gaskets
    PWR Mean Street Heads
    Copper Beryllium Seats
    Titanium Valves
    PAC 1518 Springs
    Sheet-Metal intake
    Nitrous Pro-Flow kit
    DSS 9" IRS
    1400hp Axles
    3.23 Gears
    Hellion TT Kit
    Ball-Bearing 61mm Turbos (possibly switching to Precision 6265 turbos later)
    4" Intercooler
    Eboost2 boost controller
    ATI Balancer and Flexplate
    SHR Transmission
    Weldon Fuel System
    Modified Hood
    We are not sure what wheels we will be running yet but we will be using M&H Tires. The converter will be a 2400 PI converter unless something changes in the near future. Still dont have a catback, but we are working on it. Mopar police oil cooler as well as an auxilary trans-cooler will be added. Remote 12-15 gallon fuel cell sitting below trunk mat behind rear wheels.
    Nov 2010
    Story WY.
    That's going to be one helluva setup!!
    "I'm not speeding I'm data logging" rdrd90
    Dec 2008
    Albany NY
    That is serious. what kind of manifold is that?
    Has been.
    Apr 2006
    Quote Originally Posted by Paywithdeath View Post
    Marcella manifold
    looks like Andy is thinking about going fast
    Blow it up and trailer it home!!
    Feb 2006
    CONN
    Those turbos are alittle small.The intake is pretty
    05 Magnum R/T RWD inferno red
    Franks racing Sidewinder cam w/SRT springs
    Flowmaster super 40s w/custom tails
    SRT headers and Cats
    PRO-TORQ 2800rpm STALL CONVERTER
    for converter call (203)969-2886
    Oct 2008
    miami,fl
    those heads are sweeeeeeeeeeeeeeeeeeeeeeettttttttttttttttttt!!!!!! !!!!! check out the seats on those things!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Feb 2010
    Raleigh NC
    Wow..... Cant wait to see the end result!
    May 2009
    Springfield VA
    WOW!!
    2008 300c
    392 Modern Muscle, 6.1 heads Modern Muscle
    6.1 intake and 90 TB, 3.06 Getrag, SHR trans, SRT Headers, Corsa exhaust (Tuned by Dave Foreignmuscle)
    PWR heads and Cam PB; 12.91@108.24mph
    PWR Stroker 12.41 @ 115.77
