Results 1 to 4 of 4
    Oct 2017
    Northern Spencer Gulf South Australia
    Bent upper control arms
    Has anyone replaced uca on 300 srt. Neil bent them at Collingrove Hillclimb .We had some SPC adjustable control arms shipped to Australia but have not fitted them yet all of your opinions are welcome good or bad.Put 275/40/20 on all round now for more grip check out Hill climb on youtube tight track for big car.
    May 2011
    Markham, Ontario
    Easy to replace about 45min per side. Unbolting the PCM makes the job easier on the passenger side (if first gen 300). Just make sure suspension is loaded before torqueing to spec. With SPC arms, you may have to trim fender liner a tiny amount to clear the arm. Old arms used to be side specific (no trimming required) - new arms are not (again for first gen Lx's).
    2006 300SRT8
    SOLO Performance Mach X3 SRT exhaust / LMI V2 True CAI / Eibach Sways / StreetEdge coilovers / Trufiber hood / AMG paddles w/TRS300 wireless controller / Grant Revolution steering wheel / Arrington strut bar / BT engine bling incl. uni-strut caps / Rohana RC-10's / Trufiber hood / Kaption Audio amps, sub and speakers / Rebadged by Nate / Interior switch lighting by Diboblo / Instrument cluster by Black Cat Automotive and Tim Stone (TRS300)
    Likes run2jeepn liked this post
    Oct 2017
    Thanks for your reply, thought there might be more to it than just replacing uca's .the liners are not very good already put holes in rears from burnouts might glass them arfter fitting SPC arms
    May 2011
    Markham, Ontario
    I was referring to front UCA's.
