Results 1 to 15 of 23
    Jul 2007
    Tofiga Island
    Question What internals makes for a quality/reliable HID Ballast???
    Theres A LOT of companies that offer HID retrofits/upgrades/etc.... i've spent the last 3 nights about 4 hours each night reading posts on em, but never found anything definate/solid.
    and i always hear of people saying just buy the stock stuff....
    and then others swear by this or that kit, while others have flickering problems, and Ballast that burn out....
    yet you rarely, or atleast in the time i've looked into em, never ever see posts about the OEM ballasts going out, or failing... no where near as widespread than some of the aftermarket. im sure some prob have, but most have opted for cheaper brands...
    i know theres plug and play setups for 100-400$... and then if you get flicker, or random shutoffs, people suggest going out and buying these 35-50$ "harnesses" that tap into a 12v power source.
    so my main question is, the DS1 or DS2 ballasts and bulbs, are there any non-b.s. ballasts out there, that are of LEGIT QUALITY, garunteed to hold up at least as long as the stock ballasts would, and not overheat or require extra harnesses and soldering in capacitors because they werent made for our cars???
    I'm not picky about the colors matching and being exact. i'm more so, FAR MORE SO, looking for the light output and function. Also RELIABILITY. i really dont wanna go through the issue of being on a road, leaving a country-ish town, travelling dark country areas and a headlight goes out cause of wasted money on a bootleg ballast from a country where it was 10 cents to make and sold to me for 300$.
    are there any quality ballasts available outside of the stock ones?
    Why sit around & watch everyone else live YOUR dream?
    Typical Forum Hypocrisy:
    Poster A: I noticed better mid-range & better throttle response
    Poster B: We need dyno proof, no car we've ever worked on had gains, but we've never done any tests.
    Poster A: (provides legit proof from multiple sources) Tests were done on my car & X amount of others. shows gains in midrange.
    Poster B: Well i dont accept that it made gains, its just there to look pretty, no car i've put it on made gains, dynos vary 5-20whp per run.
    Funny how nothing makes gains, until THEY find a way to sell it to you.
    Feb 2011
    Kansas City, MO
    Great ?? Subscribed....
    Sep 2007
    Cornelius, NC via Rochester, NY
    Regardless of specs, they probably all come from Ballast City, China.
    Buy cheap, keep a couple of spares.
    Mine have lasted for over 3 years with no problems.
    Swapped the Magnum for a '17 Charger RT 392 SP.
    How can you say 'no' to 485HP and illuminated cup holders?
    Jul 2007
    Tofiga Island
    Quote Originally Posted by goldsmi View Post
    Mine have lasted for over 3 years with problems.
    i'm guessin ya meant to say "NO" problems?
    1 question for ya, which brand did you go with?
    thats the thing/my worries... something thats built correctly you shouldnt have to by cheap and keep a couple of spares of... i mean most of us dont buy cheap wheels and keep a couple extra cause you know the ones you have are gonna bend.
    maybe its just me with modding, but i'd prefer to buy one thing, install it once and spend money on other mods... not keep buying the same parts over and over. i'd rather pay 300$ for a set that will last, than 100$ ones and buy 3 sets just to keep replacing em... cause either after that 3rd set you learn your lesson and go back to stock, or 300$ turns into 400, then 500, etc... now i understand some parts simply burn out or go bad, etc...wear and tear. however, from reading up on HID ballast, many of the offerings on the market are knock off version of major companies... which i'd prefer to steer clear of if at all possible.
    May 2010
    Orlando, FL
    Well the external look of an HID ballast can only look so much different than the other ones on the market....
    It's just like what I tell my women when they see my ugly face....Its whats in the inside that counts!
    lol
    The internals is what makes the difference. With every electric product there is always the possibility of them going out or having an issue with them, but it's the customer service and warranty that makes the difference.
    I offer a 2-year warrranty on my kits and I do not beat around the bushes. I get straight to the point and take care of things. Plus, I have less than 1% failure rate with my kits.....
    Take a look at my thread
    http://www.lxforums.com/board/f58/xe...-price-287914/
    Let me know if you have any questions!
    May 2010
    Orlando, FL
    If your looking for the most light output, I would suggest getting the 4300K or possibly the 6000k if your looking to get some good light output and a little hint of blue to it.
    My kits are all plug and play. The capacitors are also plug and play. No need to have a wire harness all over your engine bay to your battery or positive terminal.
    Jul 2007
    Tofiga Island
    Quote Originally Posted by PAPITO View Post
    lol
    i have MANY questions... MANY. Hopefully you can get most of em, i know some may be impossible to answer, but here goes...
    1) whats the reason for the majority of failures with cheaper brands vs the OEM gimmicks?
    2) i do A LOT of travelling. now currently, i have some projector lights with the halogen style bulbs. the reason why this has gotten so important to learn about the shortcomings of aftermarket HID stuff, is if i go out and get a set of the OEM STYLE projectors, theres only 1 type of bulb able to fit inside, and its not the same mounting style as a 9005/9006. so if a ballast goes out far away from home, i could see carrying an extra bulb. light and color isnt as important as function. but an entire ballast setup... bit overdone...
    if i'm out, i can gps a 24/7 walmart and go buy another 9005 bulb for the time being with the current setup. and i usually keep some reg spares. is it worth the gamble in your view to upgrade?
    3) i own a 2007, and from doing alot of reading, many of them seemed to have the flicker and cut off/on problems... example:
    HID Troubles on 07 300 Base
    First of all, great Forum you have going here, answered a lot of my questions.
    The problem I am having is the right headlight is flickering a little bit only when the engine is running, from what i have read, its the computer restarting the bulb due to the 55w 35w issue. That being said, i have 35w ballasts, with NO relay kit. I bought one with my first ballasts before i ran into this forum, but i could never get them to work consistently to drive safely at night.
    Got new ballasts from the place i bought the kit from, hooked everything up first with the relay, (i had a 470Micro F cap on the relay as well).... nothing, they would flash a bit and look like they would fire but they wouldn't do much after that. Ripped off the relay harness and connected everything directly. Worked like a charm EXCEPT for the slight flicker i have going on right now. The kit works fine stand alone, I connected it to a 12v battery and my battery charger and ran them on for like 2 hours straight with the relay kit, cap, and with out them too, and they worked perfectly.
    I put a little extra bulb (i can post a picture if you would like) idk the bulb size/number, but its the same size as the marker lights on the headlights. I have it spliced onto the right ballast plug. (before the ballast) I put it on to try and simmulate a bigger load so that my lights dont flash
    The flashing is not light strobe lights, its subtle, and my camera can hardly pick it up, but when i press on the brake pedal or i hit my Stereo on hard, the right side flickers quite a bit and sometimes turns completely off and the back on again. Neither light has EVER turned off without coming back on immediately or shortly afterwards....... If you got everything i said and have any suggestions i would greatly appreciate it! im at my wits end, im either going to buy another kit, try out some resistors to simulate more load or take it to Chrysler to see if they can use StarScan to disable the feature on the computer, thanks again!!
    Dodge Charger Forums - View Single Post - Tutorial : How to install HID lights by DynoXG
    with the 2007's being the problem childs, it seems, do your kits have anything specific to address that model year, or is it really even needed at all?
    4) you stated the capacitor was plug and play? does this connect inline as part of the harness or where at? also how resistant is it to the elements???
    5) some have stated to use the D1S setup...but then others swear by the D2S.... whats the difference between the two if any?
    Dec 2011
    Colorado
    I can tell you that when I order my HIDs I WILL be buying them from Papito because his customer service is amazing. I'd rather pay the extra money for that.
    2014 Nissan GT-R black edition. FBO E85 650 awhp
    Tell your friends.
    Dec 2008
    JERSEY
    I have installed this about 3 years ago and they are still working great no problems at all.
    Xentec i hear its hit or miss with them but i guess i been luck? (Now watch my kits go bad after this post...lol)
    May 2010
    Orlando, FL
    Quote Originally Posted by Samoan Tsunami View Post
    With the cheaper brand Ballasts the ignitor is what usually goes out. The ignitor is packed-in tightly into the actual Ballast. There is only so much space inside of a ballasts and fitting a ignitor inside of it takes away from its ability to perform well over time.
    With my kits, the ignitor is connected in-line outside of the ballast.
    I cannot gurantee that there will not be an issue down the road because sometimes un-expected issues arise. What I can tell you is that my kits have a less than 1% failure rate.
    I stand behind of my kits and I provide a 2 year warranty.
    Now if you keep your halogen projector style headlamps and install the aftermarket HID kit in it, if you ever have a problem with one of the bulbs or ballasts going out, you can still pop-in a 9006 bulb and connect the factory connector for the time being.
    I offer a relay harness or plug and play capacitors with my kits. I have sold hundreds of kits and as long as I know what vehicle the kit is going into, I can determine which setup will work best.
    There really isn't a harness for my kits. It's a direct plug and play. You connect the capacitor to the factory bulb harness, then to the aftermarket Ballast and that is all
    The capacitors are well insulated with epoxy
    The difference between the two.....
    The D1S bulb has the ignitor attached to the backside of it, which eliminates the issue of having the ignitor inside of the ballast.
    The D2S bulb is very similar to a regular HID aftermarket bulb. Its a simple plug and play and usually has an ignitor attached to the backside of it but with this bulb you are able to detach the bulb from the ignitor.
    I hope I was able to answer all your questions!
    Oct 2010
    Oregon
    Hey Samoan, I think it is time for you to join the HIDPlanet! I am sure when u read through the infomation section you will get all your questions answered.
    And a short answer to your question. Nope, not all ballasts are the same quality, although most of them share the origin of manufacture----China!
    Mods: A lot
    She is done. No More Modding for a looong time
    http://www.lxforums.com/board/signaturepics/sigpic40382_6.gif
    Oct 2010
    Oregon
    As for your question of flicking, here is the answer.
    The ballasts themselves are all able to support the HID bulbs. Problem is our car runs on computers. The Total Integration Processing Module(aka front fuse box) will constantly monitor your headlights power draw.
    For LX that come with halogen headlights the TIPM is set to read 55watt for low beam power draw, which is exactly the amount of power used by 9005XS bulbs. When you put in an aftermarket/OEM ballast, they will only draw 35watt power. So the TIPM will consider you have a faulty bulb and constantly try to reignite the bulb. That's how you get your flick problem----the TIPM just wont recognize the power draw.
    And yes, I said the flick WILL happen even if you put OEM D1S ballast on your halogen equipped car. You can either short out the feedback loop to TIPM by using CANBus error eliminators, or you can program the TIPM to recongnize the ballast you put in.
    The 1st option is the most widely used, provide it is easier to setup. The 2nd option will leave your engine bay really clear of extra wire/harness but VERY FEW people can perform such programming.(And dealers cannot do this) There will be people suggesting you use a relay harness to draw power from front positive end. Not a good idea IMO. That thing is only for jump start, not for powering your HID. I used relay myself in the best and from my experience it is not a hot idea.
    So the big question is down to whether you want to go OEM Projector or just pnp HID kit?
    May 2010
    Orlando, FL
    You do not need a relay kit^^^^
    Get a plug and play capacitors....Which comes with my kits.....Which means no extra wiring that you will see in the engine bay....
    Oct 2010
    Oregon
    exactly. the charger's front wire system is more than capable of handling hid systems.
    relay are for older cars that have weak headlight wiring.
    Jan 2011
    Los Angeles
    Quote Originally Posted by xkm121 View Post
    Just exactly what are in these CANbus error eliminators? Capacitiors or Resistors? What are the specs?
    I think these are the critical piece in making our HID kits work with the TIPM like xkm121 stated.
    I have a pair of DDM tuning eliminators in my car now, and I believe they are causing some issues. Any idea on what specs I should be looking for? Most of the descriptions online are very vague.
    Thanks,
    -310SXT
