Results 1 to 15 of 17
    Mar 2017
    Vancouver
    What does this sound like?
    Hi there,
    Does anyone know what this sounds like? It happens intermittently upon acceleration. It sounds like something is vibrating. I drive in auto stick mode. I know there is some play with the inner tie rods... could this be the cause?
    Sample 1
    Sample 2
    Thanks,
    Chris.
    2006 MRT, Blaze Red Pearl, Mopar Police Wheels with Continental ContiPureContact, Stock Rims with Bridgestone Blizzak WS-80
    Sep 2012
    Hempstead, Tx
    I hear something but very hard to distinguish. Idea of where its coming from? Power steering pump maybe?? Sounds like it chatters kinda.
    Battleship Bismarck
    2008 SRT8 Charger, Stockish!!
    2007 SXT Magnum
    2001 Ram 4x4
    2001 Town & Country Limited
    1999 Ram 1500 swb
    1998 2dr Neon Highline 5sp
    Member, Space City LX
    IG, oo_silversrt_oo
    Mar 2017
    Vancouver
    The samples are taken from in front of the ash tray. In my limited mechanical knowledge, I imagine it to be the drive shaft. I don’t feel the chattering on the floor; I just hear it.
    May 2017
    All stock driveline? I’m taking a shot in the dark because I’m not driving it but sounds like the 2 bolts that hold the driveshaft carrier bearing could be loose or a possible issue with the driveshaft being unbalanced.
    When did it start/you notice it?
    Mar 2017
    Vancouver
    Quote Originally Posted by Newoldchallenger View Post
    I’ve had the Magnum for a year and I started noticing it about 2 months ago.
    May 2017
    Quote Originally Posted by chrismah View Post
    Then I wouldn’t say that the driveshaft is unbalanced. Id start with checking the carrier bearing bolts and the bolts that secure the driveshaft to the couplers.
    2013 Challenger R/T, 270 comp cam, BES p&p heads, OCPerformance dual plane, NX gemini plate, JBA longtubes, DSS one piece aluminum driveshaft, 88mm fastman throttle body, 3.91 rear, lakewood drag shocks...too much to list
    Mar 2017
    Vancouver
    Thanks for the quick response and pointer. This gives me a place to start looking.
    Dec 2017
    If it were a drive shaft you would feel it while you drive, but take a flashlight under the car and check the guebo and bearing. But as stated, you would be able to feel a bad guibo or bearing, not just hear it.
    ​Trevor...
    Aug 2012
    iowa
    It the sound go up with increase speed or rpm? Sounds like a bad rear end to me. Mine sounded similar. Pinion bearing went iut
    Mar 2017
    Vancouver
    Quote Originally Posted by us1champ View Post
    Thanks for the response. No the sound doesn’t go up.
    Feb 2007
    L.A., Ca.
    First, what is the car
    How many miles
    Any modifications
    On 5.7 drive trains, and 6.1, the flex plate had issues and was hard to identify until you took it apart.
    I cant tell from the sound clip at all.
    No vibration or chattering?
    Get it up on a rack and brake torque it untill you replicate what you think is wrong.
    FI IV.5, Solo cat backs, 180 thermo, Catch Can, DS tuner, 383 Stroker/SRT heads,headers and mids,, Tranny cooler with fan control, built tranny/flex plate/4K conv,09 Chally rear with Quaife posi. Pedders Track II, coil overs, Hodgkiss sways, BWoody links, 20" Jacks N Five with Nitto Invo's, Custom brakes by TCE. Bling by BT.
    Just a grocery getter!
    Feb 2012
    Orland Park IL
    sounds like a wookie. Do you see a very large and hairy dude in you back seat? If you do, tell him to be quiet. If you don't...look in the trunk.
    2007 BB Charger SRT8
    12.133@111.42, 1.762 60' 620 DA
    Likes ramblinmike, Hal'sMag, Al Evans liked this post
    Mar 2017
    Vancouver
    Quote Originally Posted by Hal'sMag View Post
    How many miles
    Any modifications
    It’s a 2006 Magnum R/T, 82000 km (or 51000 mi), and stock except for a catch can.
    I don’t feel the vibration, but I do hear it.
    Feb 2007
    L.A., Ca.
    Hear but don't feel. It isn't tie rod ends.And it does sound like a wookie.
    If I'm hearing it right, it sounds the same regardless of engine RPM, which is good. So' it doesn't change with speed either?
    As RPM and speed increase, which appears to happen, the tone and resonance don't appear to change.
    I'd get it on a lift and look for anything loose. You can check driveshaft then, but that should change with speed.
    I picked up some bailing wire around my driveshaft on a trip to Vegas, and the hollow driveshaft made weird noises that drove me crazy, even coasting down a hill.
    That makes me think you should try under power and coasting to try to sort this out. If it's only under load, look to the drive train. If it's present when coasting, look to the wheels and axils.
    Mar 2017
    Vancouver
    I can hear the sound only when accelerating. So if I understand you correctly, this means I should look to the drive train. I'm not sure if it changes with speed because it lasts only for a few seconds. By the time I try and lock in the RPM, the sound is gone. My samples are an combination of multiple instances.
    I haven't noticed the sound while coasting, but I'll keep my ears open.
    Thanks for the tips.
    Chris.
