Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Mar 2009
    Edmonds, WA
    Guess these guys are wrong too.
    But I mean its all up to you. Might work but I would do some serious degree and clay checking myself to even think about it in a stock 6.1 or you could end up like his first build.
    Cam question for 6.1 gurus
    Sent from my SM-G925V using Scat Pack Forums mobile app
    2008 Magnum BB R/T Hemi Registry # 1584 PPP Stage 2 Cam, JBA Shorty Headers, JBA High Flow cats, Heartthrob Exhaust, Eagle Intake, LMI Intake, MTCM, Blue Tops, ProTorque Converter, SRT Rear, Techo Strut Brace, lowered, Tuned by Diablotoona SOLD--2005 Mineral Gray AWD Hemi Registry # 1154
    For the work being performed, length is far more important than diameter :^)
    Dislikes baja272 disliked this post
  2. #17
    Mar 2009
    Edmonds, WA
    Quote Originally Posted by baja272 View Post
    Well, simply stated your wrong. if your knowledge is based on internet trolling, you just showed your ignorance. you obviously are a poser with limited knowledge....I will extend a money back offer to the OP. That having being said, you are the reason I avoid these forums. Instead OF BEING A NAY SAYER, LISTEN AND LEARN
    Well sone of us that have been here a while dont enjoy sellers telling obvious less inclined mechanically that it'll just slide right in no problem on a custom grind cam with stock motor. Need to adnace it? Need adjustable timing set for that. Maybe pop up a clear photo of the cam card so the guy can ask around
  3. #18
    Nov 2013
    Yep Wanna be racer. different cam that sheared the pin and was replaced by Lunati. they had a problem with this due to poor metalurgie on a series of cams back then.
    I will happily debate your lack of knowledge any time. just sayin check out the hemi race series for my name. and here is the fairy tell for you. just send some proof of your racing skills afterwords
    Quote Originally Posted by Gdragich View Post
    Yup, you know your stuff alright
    HELP after new cam, heads, throttle, body, intake...
    2006 Black GCSRT8, R1s d/s, BilletTech. Catch can, Bwoodys end links, Demon Perf. adjustable panhard bar, Eibachs, PWR cam, mean street heads, Arrington throttle body, kooks headers and cats, paramount , Demon fuel rails, ATI 5% OD dampner and more soon....
  4. #19
    Nov 2013
    Why, so you can reproduce it for your benefit? you are the typical keyboard specialist, have you even made a quarter mile pass (prove it). have you ever taken the time to think, maybe you aren't the most informed individual in the room. ill happily take this to PM with you so the OP does not have his thread derailed.
  5. #20
    Jun 2017
    Denver, Colorado
    All good guys. I'm def in the less mechanically inclined category so any and all information is appreciated. I read through the thread that was linked from 2014. Sounds like after things got worked out there were no issues with the can. It is that a different cam that you were running. Why the issue with the cam lift if the heads are made to accompany it? Baja you were running this head and cam together correct? Wouldn't the tune take care of spark advance, timing etc... I'm def going to get a tune done when I install heads and cam no matter where I source them so wouldn't that take care of those issues. Sorry for my lack of knowledge with cams and thanks for all replies
    2007 MSRT8- 180 tstat, afe cai ,Kooks LT and cat mids magnaflow mufflers, Trinity tuner, hemituner tcm, strut tower brace, bt catch can, 20" Lorenzos, FTI3800, ATI flex plate, vfn cowl hood... lowered just a little... in Denver at a mile high
    MODS NOT INSTALLED YET PWR MEAN STREET HEADS, Custom Cam, Procharger D1sc ,80 lb injectors. This is an addiction
    Best Time @ Bandimere, CO..... 8/20/2017....soon to change lol.
    RT- .376
    60- 2.029
    330- 5.827
    1/8- 8.946
    MPH- 80.19
    1000- 11.622
    ET 13.907
    MPH 97.7
    -Aaron
    ‚Äč
  6. #21
    Nov 2013
    Same cam specs, but due to the failure of the pin, Lunati reproduced the cam (new cam, same specs). the heads have the bronze valve guides, springs keepers, and retainers that allow for the higher lift from the cam, eliminating the potential for coil bind (and the reason why the SRTmax cam is limited to its lift).
    I was running this combination in the video. You will need a custom tune and the reason I recommended Yohan (Diablo) is because he is the one that developed the tune I was running. No apologies needed, I'm happy to assist people with the same desires as I have. You just need to go to the dragstrip and enjoy the adrenalin rush that comes from racing the 1/4 mile......
    Quote Originally Posted by SNOMAN1174 View Post
  7. #22
    Jun 2017
    Denver, Colorado
    Just to let everyone know I think Jeff is a standup and honest guy. Had a nice conversation this morning about the heads and cam. I think the guy has raced anything that has had a motor. Really sharp guy that is currently building something really "pissed off and mean" but I will let him elaborate on that. It really put my worries at ease. Ive sent payment!
    So on to the next piece of the puzzle....what torque converter and which stall? Kinda initially feeling a 3400 or something in that neighborhood. Probably get a valve body at same time. So, Im ready for suggestions! Jeff reccomended Paramount so I will be reaching out to them but looking for any and all opinions
  8. #23
    Nov 2013
    Thanks Snowman. I appreciate the comment.
