Results 1 to 9 of 9
    Mar 2017
    Burnt oil smell... kind find it
    2013 300c 5.7
    Every now and then, I get a whiff off burned fluid... like oil on a manifold kind of smell. it happens intermittently and isn't always repeatable. I've had the car on a lift twice and can't find any evidence of a leak.
    Are there common leak points I should check? What about that trans leak from the 1st gen lx's... does that effect us too?
    driving me crazy.
    Sent from my SM-G930V using Tapatalk
    Nov 2010
    Valve cover? Just guessing.
    Mar 2017
    Quote Originally Posted by guyd_15 View Post
    I've been all over this thing top to bottom. not a single noticeable leak or weep anywhere on the trans or engine. driving me nuts
    Feb 2012
    Orland Park IL
    I too would guess valve cover. I've had a bad gasket that would only leak when I got the rpms up, and would drip on the headers and smoke. it can be hard to see. if you haven't already use an inspection mirror on the passenger side valve cover, up by the firewall.
    2007 BB Charger SRT8
    12.133@111.42, 1.762 60' 620 DA
    Mar 2011
    This will sound weird, but I was smelling that same smell until I had the alternator recall done. I haven't sensed that smell since.
    2013 300S AWD 5.7L V8 HEMI
    1987 Shelby Lancer #63 2.2L Intercooled Turbo, MOPAR Stage II
    Mar 2017
    Quote Originally Posted by neonsox View Post
    ok so, now that you mention it, the smell started two weeks ago AFTER I got the alternator recall done.... isn't that somethin....
    May 2005
    Fairport, NY One retired Magnum RT, two 300s still going.
    Quote Originally Posted by RoamingCoastie View Post
    You may be leaking alternator fluid! :-)
    Mar 2017
    Quote Originally Posted by Pushbutton View Post
    bahahaha
    Oct 2016
    My 5.7 (2008) began to occasionally produce a hot/burnt oil smell. One day it got really bad. Looked under the car and saw (*gasp*) oil dripping off somewhere near the back of the engine. Turned out on of the MDS solenoids developed a leak. My buddy, the Snap-On dealer, crawled in with a mirror and spotted oil running out from under the intake and down the back of the block. I replaced all 4.
