Results 16 to 30 of 37
  1. #16
    Nov 2014
    How did you determine the first head gasket failure? Didn’t have these symptoms right?
  2. #17
    Nov 2014
    iirc you’ve had a valve seat drop before, and a big issue with a previous motor swap? Is this a whole separate engine/car? I assume these are different heads and you did not reuse the intake manifold like advised to others many many many times before.
    What’s the story here?
  3. #18
    Sep 2012
    Hempstead, Tx
    Battleship Bismarck
    2008 SRT8 Charger, Stockish!!
    2007 SXT Magnum
    2001 Ram 4x4
    2001 Town & Country Limited
    1999 Ram 1500 swb
    1998 2dr Neon Highline 5sp
    Member, Space City LX
    IG, oo_silversrt_oo
  4. #19
    Jan 2014
    Hampton Roads
    Quote Originally Posted by BradJo9 View Post
    The first on my ownership, I went and did some hooning. Dropped a seat, of course the gasket went with. It had the usual, won't start won't run, issue of a dropped seat.
    I had a dropped seat prior to purchase and the recent one back a few months ago. Same engine, same car. Different heads Everytime. Different intake as well. I've overheated it once but it didn't cause a seat to drop nor did I overheat it for minutes. It was merely seconds and mm over the halfway mark because of one extremely hot day in the 100s here. I stopped the car and stopped driving.
    Sent from my Z981 using Tapatalk
    Previous
    '10
    Charger 3.5 (STORM!) (Engine)
    '10 Charger 5.7 Hurrache (Hurricane) (Engine)
    '10 Charger 5.7 Alexis Mercy Mercer (Mercer) R/T Police Package (Taken) but not forgotten
    '05 Chrysler 5.7 300C "Hemmissy"
    @Hemmissy_300C
  5. #20
    Aug 2012
    iowa
    🤦🏻*♂️ I am lost lol
  6. #21
    Nov 2014
    Sorry I meant to put my question on his other thread titled head gasket failure.
  7. #22
    Jan 2014
    Hampton Roads
    Quote Originally Posted by us1champ View Post
    🤦🏻*♂️ I am lost lol
    As far as?
  8. #23
    Aug 2012
    iowa
    The guy said you posted in another forum you sold them car?
  9. #24
    Jan 2014
    Hampton Roads
    No. Must've been the wrong person
  10. #25
    Jul 2016
    Dude, I hate to say it. But take it to a shop. I’ve seen 4 or 5 posts about this SAME CAR! YOU DON’T KNOW WHAT YOU’RE DOING! PLEASE STOP!!!
  11. #26
    Sep 2012
    Hempstead, Tx
    Quote Originally Posted by jerrytotin View Post
  12. #27
    Jan 2014
    Hampton Roads
    Hemi compression test write-up?????Hemi compression test write-up?????Hemi compression test write-up?????Hemi compression test write-up?????Hemi compression test write-up?????Hemi compression test write-up????? thanks for your suggestion!!! I'll do as you say master!!! Youre paying right? I'll await the transfer!
  13. #28
    Jul 2016
    Quote Originally Posted by Kid_Storm View Post
    With all the money you’ve wasted so far you could’ve already taken it to a shop. And since apparently you’ve done all the work you’ve wasted all of your own time parts and money for the cost of the parts and now you’re in the same position as before. I’m only making a suggestion ,but I’ve seen this post a lot and you’re not getting any help from anybody because I don’t think you know what you’re doing. You’ve clearly screwed something up and now you’re trying to fix it but you don’t know even know what you did.
  14. #29
    Aug 2012
    iowa
    I am just confused on what did you originally do. Was it something with a busted valve seat? If I was you I would send the car off to someone . Look I appreciate the fact you want to do it yourself. Trust me society in general needs to learn more of this. But at some point you need to know when to let go and have someone else. If you can’t afford to then let it sit till you can. Tinker but don’t sink money into something more than you already have without knowing what you are in for.
    Trust me. I get it
  15. #30
    Jan 2014
    Hampton Roads
    Trust me. I get it
    You both are absolutely correct. I will sit down, wait until I have a few thousand dollars, and give it all to the dealer to fix my issue. Thank you!!!
