Results 1 to 12 of 12
    Nov 2007
    socal
    3rd brake light not working
    I thought the old one was bad, so i bought a new one @$54, and it still doenst work. looked in the manual, but it doesnt list a fuse # for the 3rd brake light. I looked through the fuses, and didnt find any blown. Does anyone know what # the fuse should be or where its located?
    Feb 2007
    zion, illstate
    not sure but i had the same problem. turns out the light wasnt connected when i pulled the rear deck off.
    Nov 2007
    socal
    I just installed it so it should be making connection
    but i wonder if it has something to do with led brake lights
    Feb 2007
    zion, illstate
    i would try and test if you even have power at the 3rd brake light. that way you can start to eliminate things. i didnt see anything in the owners manual about the rear lights when i comes to the fuse for the taillights
    greasy cardboard box
    CHMSL is powered by the same circuit as the stop lamps. if they work, the circuit is working up to S348 splice where it splits to left/right/CHMSL.
    it might be easier to help you if we knew what you're driving.
    please update your vehicle profile in User CP. thanks.
    Braintree, Massachusetts
    Exclamation
    X2. Without knowing what you own, for the sake of arguement, lets say it's a Magnum, Charger, or 2008 and newer 300. Check the decklid/liftgate wiring. The wirring can break from repeated opening and closing. You'll have to undo the rubber boot to examine the wire. But please do update your vehicle profile in the user CP.
    2017 Dodge Charger R/T Scat Pack - Go Mango
    Nov 2007
    socal
    I am going to look at the connections today,
    I updated my profile. I have an 06 Charger RT.
    I am definetly going to check to see if its getting power. I think when my suitcase broke off the tabs, I must have been getting water in there through the gap. I never noticed anything wet in the trunk, but when I was checking the fuse box in the trunk I could see some residue trails from looks like water dripping down the FATMat stuff.
    as Tbird said, repeated opening/closing of the trunk lid can cause a break in the wires in the trunk lid jumper harness. if no power or no ground at lamp unit, best check that first.
    Nov 2007
    socal
    I bought a tester, and there isnt any power at the plug
    the trunk opener still works. I guess tomorrow I will start pulling back the black tape and see if I can find where it lost connection.
    Does anyone know if this is covered under the extended warranty, or is it something I should try to do myself. I will probably stop by the dealer and have them check my warrranty to see if its covered.
    depending on which plan you purchased, it may well be covered.
    Nov 2007
    socal
    They said it might be covered if they find its a defect
    said they would need the car for about 3 hours, so I am assuming that if they find the wire separated within the hood or harness, they would cover it as a defect. If not, I will have to cover the 3 or 4 hours.
    Cool
    Quote Originally Posted by QuickD View Post
    It shouldn't take 3-4 hours, all they have to do is pull the boot partially out and find the appropriate wire, and fix it if broken. The wire runs into the body, then to the rear PDC, where there is an internal splice for the brake lights. Should be 1 hour- 1.5 hour tops if it's just the wire to fix. (It can be a little tight with the boot in the way, just be prepapred for a higher charge in labor).
