Results 1 to 15 of 18
    Jun 2006
    Bridgewater, MA
    Tip to remove/loosen tie rod end jam nut
    Holy crap. I cant get this sob to budge. it's the nut at the end of the outer and inner tie rod. No matter what I do i cant get that nut to budge and cant unscrew the end. I have it separated from the hub knuckle thinking that might allow for more leverage but nothing. Why cant anything be easy....
    Any hints? I'm close to puttin git back together and over paying a garage to do it.
    Thanks,
    Brendan
    2008 300C SRT8
    Previously: 2005 Bright Silver Magnum R/T
    Texas
    Have you tried pentrating oil, and let it sit for a little while?
    2017 Challenger Scat Pack 6spd Torred. Mods: Mids Delete, Windows Tinted.
    Nov 2007
    Good quality socket, breaker bar and cheaper pipe man. SiliCroil creeping oil or the like might help too. Have someone tap on the tie rod end stud with a brass hammer while you have a big bind on it - the oil will get in and it might pop loose.
    Good luck, I hate this type of pinch.
    X E Ryder
    Just Another Motorhead, Really.
    Sep 2007
    New Hampshire
    Quote Originally Posted by Mungo View Post
    Thanks,
    Brendan
    You may be able to spin the outer tie rod the off the inner with two pipe wrenches after you drop the outer off the spindle.
    5.7L Hemi Registry # 00814
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by X E Ryder View Post
    If this ^^^^^^^^^^^ don't get it
    well, there's always this
    Oct 2005
    Riverside, Ca
    And this
    Braintree, Massachusetts
    Exclamation
    Thanks,
    Brendan
    The first thing you do BEFORE removing the tie rod end from the spindle is loosen the jamb nut. On the left side, rotate the wrench towards the front of the vehicle (wrench pointing down, rotating in clockwise direction looking into the wheel well). For the right side, rotate the wrench towards the rear of the vehicle (wrench pointing down, again in a clockwise direction looking into the wheel well). A pipe on the end of the wrench adds leverage if you don't have the strength.
    2017 Dodge Charger R/T Scat Pack - Go Mango
    Maybe these vids will help.
    The tie rod jam nut came off real easy on both of the vids.
    Try reattaching the tie rod arm to the steering arm/knuckle and keep trying to loosen the jam nut.
    Jun 2006
    Bridgewater, MA
    Thanks for the quick responses. I have plenty of tools and pretty much everything mentioned above. I only have 10w40 but that seems to have helped somewhat. I tried loosening it first. I finally got the rod end off but but there is a decent amount of fluid coming out of the boot now. There was a slow leak before, I think my inner rod and/or rack is gone. My force and moving things around havent seemed to have helped too much!
    On to the passenger side. Thanks for the wrench direction, TBird. I know righty tighty, lefty loosy but still seem to get caught on this.
    Jun 2006
    Bridgewater, MA
    Thanks for the video. I wish mine was that easy!
    Question fore you guys, how easy should the inner tie rod spin? mine seems to spin extremely easy.
    Mine moves real easy. Here is a vid of my 300c.
    Jun 2006
    Bridgewater, MA
    thanks. Well the passenger was very easy and is already done. Driver side was just a complete bit*h. Oh well.
    Does anyone happen to know the p/n number for the inner? I know I can search later just all greased up. There is definitely an issue with my inner and I believe that can be replaced separately if I remember correctly. Thanks for all the help guys.
    Apr 2008
    Hainesville IL
    Heat it up with a torch, it'll come loose right away, get it glowing orange and go from there....
    Exclamation
    Just remembered- if the inner breaks loose but the nut doesn't move just lock a pair of vise grips on the inner tie rod an d while holding the vise grips turn the nut. Lube the inner tie rod threads to ease re-assembly. If you have fluid leaking from the rack boots you have a bad rack. The new rack comes with outer tie rod ends.
    Jun 2006
    Bridgewater, MA
    awesome... just replaced the outers for nothing.
