Those who have bought the new European Headlights, can you give me some direction on how to install. I just bought a set (black) and they have no instructions on how to hook up the wiring! I would be greatful for any help!!
300 (SRT) front, MSRT rear bumper, shaved rear wiper, 402 rear spoiler, RK/Sport raised hood, Grip grille, Boss 304 18" wheels, 245/55 BF Goodrich tires, painted coolant tank (402), painted engine cover and ABS cover, LED tail lights and side markers, LED lighting in engine bay, MagnaFlow High Flow Cats & exhaust, Vortech V-3 S/C, Vortech Predator tuned, 180 Tstat, X-treme Duty Radiator, Billet/Tech engine dress up, B/T oil catch can, Painted radiator cover! A big Thanks to Rod Burton who did the conversion & S/C install.
When's the next time you'll be in Orlando? We've helped install new lights on 2 cars already...wouldn't mind another..![]()
What european headlights?
This week I am only free to go to Orlando on Thursday. I live in Ocala. I'm ted up this coming weekend 1st and 2nd. I could possibly do the following weekend. That's the weekend of Toys for Tots in Old Town.
Those are European?
That's what they call them where I bought them. The rings around the outer lights lightup. They call them angle eyes. The three smaller lights are LED. I have seen them on the new BMW's. A few guys have already have them. I also bought the LED tails to match.
Here is a picture of the back, if anyone that has installed them can tell me how to hook up the wiring.
Do a search for "projector headlights", "projectors", or "ebay projectors" these have been talked about for quite a while. There's a chance someone made an how-to thread.
though i havent seen these im pretty sure how they hook up
for the high and low beams you would hook them up according....not very hard one plug in has 2 groove slots inside the plug while the other plugin has one inside......for the sticker that says remove just lock in your blinker lights
for the led wires and cathodes you will either want to wire the whites up to power using your parking lights or a switch and run the black to the ground.....
your better off putting all the whites together on one switch then having multiple switches........let me know if this helps.....if any thing we could possibly meet up and do the install somewhere.....
the top seems to be a hook up for an accessory light or that actually may be your bilnkers
if ya could take off the stickers and see if there is a groove lock for the headlights......it may be for your fogs........
Thanks for all the replies guys. It's nice knowing you can go to the forum for help when you need it. It looks like the top hole would be for the blinker. Looking at the front it would be the long straight light. What puzzles me is the third hole. The outer light is the blue tinted lens, then I guess the middle would be high beams, third? I have the fog lights on the bottom of my front grille! So I am at a loss on that one. There were several of our members with this type of lighting on there magnums. I saw them at the Mopar show in Ocala. I liked them so much I had to get them for myself! KGBPro, I think you are on the right track on most of it.
I had these lights..Outer blueish is low beam , then high beam, and then your turn signal socket goes into the inner most one. Then you will have your stock side marker socket/bulb left, and it goes into the top hole to light that long clear led bar above the chrome strip. This light comes prewired and with a side marker bulb already installed. That is how you have your stock side marker light left, which goes into the top as I mentioned above. Hope this is clearer for you.![]()
Thanks Lowriderman. That makes sense. May I ask why you no longer have the lights? I like your lights in the photo, looks cool.
