Edit: He changed his mind due to complexity.
Its not a straight swap you need to customize the fenders so that the body lines match
You are including the fenders. It will all bolt up as is, but the fenders will stick out without being fabbed to match the magnum body line. Chargum is making molds of his fenders right now, so all you would need are a set of his fenders to make a chargum. Now to make a mag front end fit on the charger, the fenders will have to be fabricated from scratch since no one makes a mold.
