Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
  1. #31
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    Quote Originally Posted by slideway View Post
    Ok, I generally see the same thing when I run, Trans heat and motor temp. come into play, It's hard to speculate. I can never launch the same exact way each time it seems.
    I never pull up to run unless I get to the right temps, thats probably the only thing you have control over all the other things track prep and weather and stuff you don't.
    But the question is not how good the 60 ft times are its how can 1.78 60ft times produce better results that 1.68 60 ft times with everthing else being the same.
    I don't think its all in the upper end because the 1/10 difference is already gone by the 1/8 mile
    Who knows, anyways that engine is gone and buried and another one will be going in hopefully in around a week
    Video
  2. #32
    metgo's Avatar
    metgo is offline Life is too short to be driving slow
    St. Louis
    Quote Originally Posted by nhdave View Post
    Depends on how quick you can get the 60' down. I think I remember our resident expert says you can gain about two tenth for a tenth off the 60.
    Quote Originally Posted by torRed #1169 View Post
    So after putting on Drag radials and Torque converter what am I looking at time wise improvement ???
    Steve recommended taller DRs not 275/40/17 but 305/18 and he explained why but it was little over my head and I only got half of it.
    He also said to get 3200 stall Precision TC.
    Based at looking at a lot of my time slips, I'd saying improving your 60' by 1 tenth will give you about .15 seconds. I'd say a converter is a good for 1-2 tenths on your 60'. So converter alone should be good for .15-.30 in the 1/4. I haven't run my current setup on street tires yet but I estimate that since my 60' is only about a tenth better on DRs that I only picked up 1-2 tenths.
    Quote Originally Posted by JusticePete
    Even bad pub is good for business.
    In my years of business I have found that there are three truths: the customer's truth, the busness owner's truth and the truth that lies some where in the middle. No additional commentary is required nor would it would serve no purpose.
    My Pedders Experience
  3. #33
    slideway's Avatar
    slideway is online now Onward, through the fog
    Jun 2007
    Union co. N.J.
    Quote Originally Posted by InferAl View Post
    Hmmmm! New motor
  4. #34
    X E Ryder's Avatar
    X E Ryder is offline Open Course Road Racer
    Nov 2007
    Southern California
    Gratz man that is awesome!
    X E Ryder - Laguna Seca 1:54
