The following is one of many methods you can use to get pictures to show within your posts. The following tutorial assumes you're running a Windows operating system:
1) Open your PhotoBucket account ( www.photobucket.com ). I have the premium account, so the following instructions are based on it. I'm assuming you either have a premium account, or the basic account has the same link ability.
Uploading pictures from your harddrive to Photobucket is covered in the help on the Photobucket site.
Once open and after uploading your pictures, you'll see something like this:
2) You'll notice three boxes under each picture. Its the third box you're going to want to use. Click once in that third box, and the whole link should highlight.
*NOTE: If you see a little pop up at this point that says "Copied" you can skip to step 4.
3) Once highlighted, press and hold the Ctrl button on your keyboard. Now, tap the 'C' character and release both. You've now "copied" the link to your "clipboard".
4) Now, find the "Post Quick Reply" box at the bottom of this thread. Place your cursor inside that box, so that its blinking.
5) Press and hold the Ctrl key again, but this time tap 'P', then release. You should now see something like this:
You've just "pasted" the link from your clipboard to the new post area.
Repeat this step for every picture you wish to add. Once done, click the "Post Quick Reply" and all should be good!
...the next
Slvr Bullet is a 06 Charger R/T.
