Page 1 of 7 123 ... LastLast
Results 1 to 15 of 99
    CoolVanilla's Avatar
    CoolVanilla is offline The Dude Abides
    2005 Dodge Magnum TSB's
    http://mofocertified.com/2005_tsb_magnum.html
    I recommend downloading the Index file first, as it will give you a short description for each TSB. Note the TSB number, and download/view that file.
    Enjoy!
    Magnum PI's Avatar
    Magnum PI is offline Bike Wagon
    Oct 2004
    Hilo, Hawaii
    Thanks Cool vanilla, but where can I find TSB 2301805?
    Magnum PI - Hilo, Hawaii
    05 Black Magic Magnum RT, Zoomers, Eibach pro-kit springs & Dampers, Chrome ASA GT5s w/ Toyo Proxes4 255/45 x 20, Frankentake III
    00 Trek 5200 USPS Bike & 09 370Z sport
    Nightshade's Avatar
    Nightshade is offline LX Guru
    Kitchener, Ontariooooo
    There is also a TSB 21-011-05 dated April 23, 2005.
    Models: 300/Magnum/Charger/Grand Cherokee (WK w/3.7L, LX w/ 5.7L, or LX AWD w/3.5L) equipped with a NAG1 (W5A580) transmission (sales code DGJ).
    Model year: 2005
    SUBJECT: NAG1 (W5A580) Transmission - Shudder When Torque Converter Clutch Engages
    OVERVIEW: This bulletin involves thoroughly flushing the NAG1 (W5A580) transmission of any water contamination, replacing the transmission filter, and applying RTV sealant around the base of the transmission fill tube to prevent water intrusion past the fill tube seal.
    SYMPTOM/CONDITION: The customer may experience a transmission shudder when shifts occur. The shudder is most noticeable with partial application of the torque converter clutch in 3rd and 4th gear.
    DIAGNOSIS: If the customer experiences the condition perform the Repair Procedure.
    LonghornSpencer's Avatar
    LonghornSpencer is offline Hook 'Em Horns
    May 2005
    TEXAS...D/FW
    Are all of these for all Magnum's or are the engine specific? What is the protocal for getting a dealership to take care of this? Do I just call and set up an appointment and tell them that I want TSB so and so and this flash?
    THANKS CoolVanilla Big Help!
    fnkychkn's Avatar
    greasy cardboard box
    some cover the entire LX platform, others are model/engine specific but most are build date specific. you'll have to read them.
    once you find one that describes your symptoms, simply explain your symptoms to service advisor and mention that you foun a TSB describing these symptoms. they should take care of the rest.
    Nimcosi's Avatar
    Nimcosi is offline LX Padiwan
    May 2005
    Quote Originally Posted by nightshade72
    Model year: 2005
    How is this one different that 21-006-04 from April 2004. If it is new, can we get a copy added to the archive, I find having the actual TSB in hand helps immensely.
    cujo is offline cujo
    NY
    Nimcosi, 21-006-04 deals with the V6 engines and 21-011-15 is for the the 5.7L V8 Hemi engines. The fix is generally the same, but the part numbers may be different.
    Cujo, 2005 Black-RT
    Nimcosi's Avatar
    May 2005
    Quote Originally Posted by cujo
    Excellent, now if someone would upload it to the share.
    jarrod is offline LX Padiwan
    Feb 2005
    Houston
    What is the TSB for the rough idle for the V8's? All i can see are for the lx's.
    JL
    HEMI ONNNNN!!
    05 RT, loaded. AirHammer, JBA Shorties, Hi Flo Cats, Zoomers, SC tuner, 2 JL 10's, JL Amp, Eclipse Amp, Boston Pros in rear, BFG KDW
    more to come
    magnum guy's Avatar
    magnum guy is offline LX Padiwan
    Aug 2005
    Arizona
    Thumbs up i love forums!
    i'm the new guy here and this is post #2 woohoo!! this is the kind of post that i love, stuff that i wanted to know but never could find. thanks guys....
    Hi Jarrod... I'm not sure I understand your question.
    LX defines the body style.
    The LX currently comes with four engine options. You'll notice that all these TSB's are for the LX. If you have the HEMI, look for those that apply to the 5.7L.
    That help clear up any confusion?
    Feb 2005
    Houston
    Didnt mean to put LX. The TSB i saw was for the v6 rough idle.
    JL
    HEMI ONNNNN!!
    more to come
    BCs300z's Avatar
    BCs300z is offline LX Newbie
    Aug 2005
    Belgium
    I am new to owning a Magnum RT and new to this site. I have been reading all night on this topic of TSBs and the like.
    I just rolled 1K miles today on my way to work. Only owned the car for a week and a half. And I have noticed that at stop lights the car is shaking. like there is missing or hesitation going on. Much like this rough idle being talked about. I can't seem to find any info here on the 5.7 with rough idle.
    And here is the kicker....I am in Europe! The Magnum does not exsist here. I own the only one I have ever seen in the 2 1/2 years I have been here. So I need as much ammo as I can have in hand when I go to the dealership here as the language barrier is a real PITA!!!!
    Magne300Csium's Avatar
    Magne300Csium is offline "R" is for race
    Jan 2005
    Eastern Ventura County, CA
    Is there a way that all LX TSB's can be part of the downloadable list? I see a lot of Magnum TSB's, but there are quite a few 200-specific TSB's that are not on the list.
    Any assistance you can provide would be excellent.
    His: 2006 300C SRT8
    Silver Steel with All Options
    Plus: 275/40/20 Toyo Proxes 4's, Volant CAI, Mopar/Corsa Cat-back Exhaust, Satisfied Brake Pads
    Hers: 2006 Jeep Grand Cherokee SRT8
    Bright Silver, with All Options
    Plus: Satisfied Brake Pads/R1 Drilled/Slotted Rotors
    Theirs: 2001 Mustang GT Convertible
    K&N FIPK, Magnaflows, Steeda Tri-Ax Shifter, Mach 1 & Cobra Trim
    Theirs: 1970 Challenger R/T SE
    Sublime Green, 440 4BBL, 727, power steering & brakes
    Theirs: 1969 Roadrunner Convertible
    Sunfire Yellow, 383 4BBL, 727, power steering & brakes, factory air
