Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Like Tree1Likes
Thread: Underhood Engine Light Mod Write Up!!!! *
    pdogg57's Avatar
    pdogg57 is offline I'm hugh in Honduras!
    May 2006
    Thumbs up Underhood Engine Light Mod Write Up!!!! *
    here you go guys, enjoy.
    Underhood Engine Light Install Write Up
    1. Parts/Tools
    • Hood Lamp: # 56021441
    • Wiring Harness: # 56051176AB
    • Extra liner fasteners
    • 18 gauge wire
    • In-Line Fuse
    • Wire loom
    • Wire connectors
    • Loops/hooks
    • Wire strippers/crimpers
    • Electrical tape
    2. Remove Hood Liner
    • Carefully pull back one or more tab to expose fastening clips. Pinch the clips with needle nose pliers and carefully remove. I removed the entire liner but this is not necessary, just make sure not to bend the liner too much or you’ll end up with a permanent crease.
    3. Run Wire Harness to Engine Bay
    • Once the liner is removed (partially or fully) run the wiring harness to the engine bay following the windshield washer fluid line. Make sure to remove the fasteners on the harness, they don’t match anything on the hood. Attach the harness to the washer line with zip ties.
    4. Remove End of Wiring Harness, Connect New Wires and fuse, loops/hooks, wire loom
    • Remove the end of the wire harness and connect extra wire and wire loom. I used electrical tape to secure against potential moisture. Cut wire with enough slack to connect to the fuse box. Attach in-line fuse on the positive wire. Crimp loops/hooks and secure with electrical tape.
    5. Trim Slot in Foam
    • I ran the wire loom down the side of the engine bay where I trimmed a slot in the foam shown here. You can choose to follow the washer line into the engine bay but this means drilling a hole in the fire wall.
    6. *Reattach Hood Liner Making Sure That Wiring Harness is Accessible
    (Prior to this step you might want to make sure everything is working correctly.)
    • Make sure the wire harness is secured properly and all zip ties are trimmed down.
    • Reattach liner making sure that the wire harness connector is protruding through. This is your last chance to make sure everything is sitting right before you complete the reattachment. You can always re-remove the fasteners but this just heightens the risk of breaking them.
    7. Trim Hood Liner Fastener and Attach Lamp Housing
    • You’ll have to trim the clips on the fastener you use to attach the lamp housing otherwise it will not clear the liner or hook on to the hood correctly.
    • Once lamp housing is attached attach wiring harness.
    8. Connect Ground Wire and Positive Cable
    • Connect the ground wire to ground terminal located on the wheel well.
    • Connect the positive wire to the positive terminal on the side of the fuse box. You can also choose to connect to a fuse within the box but I chose this method instead
    9. …..Enjoy
    fnkychkn's Avatar
    greasy cardboard box
    you might want to install an inline fuse as close as possible to the B+ connection. i'd hate to see your ride go up in flames in the event of a short.
    great mod btw.
    Bo's Avatar
    Bo
    Bo is offline Because Unicorn
    Mar 2004
    Austin, TX
    great mod btw.
    PLEASE...... install a fuse!
    --Bo
    crhemi's Avatar
    crhemi is offline LX Padiwan
    Dec 2005
    Kauai, Hi
    Nice, please update with fuse.
    lowriderman3's Avatar
    lowriderman3 is offline Rut Ro!
    Low Down Dirty South!
    Anyone have the part number for the hood liner fasteners?
    fnkychkn's Avatar
    4878883AA $6.35 cdn. each.......ouch!
    Thanks...I found the part number..That is for a pack I am sure from when I ordered.
    pdogg57's Avatar
    May 2006
    great mod btw.
    Quote Originally Posted by Bo View Post
    --Bo
    Quote Originally Posted by crhemi View Post
    oops!!! thanks for catching that guys. I posted the fwrong write up. I wrote this one before I realized I needed an in-line fuse. I knew I was missing something. the write up is now updated to include a fuse. thanks again.
    the fasteners are a little under $3 at moparsupercenter.com
    catzcradle's Avatar
    catzcradle is offline Flamed
    Disneyland
    so is the light tilt-sensitive? Nice write up!
    2005 SXT 3.5L V6, For mods, pictures and video, check out the car's home page
    thewagon's Avatar
    thewagon is offline Hurry up and get here Summer!
    Jun 2005
    Sparks, NV
    yes it is tilt sensitive. works great
    2005 Inferno Red Magnum R/T & 2010 RAM 1500 4x4 Hemi
    Retired USAF/USANG 22yrs, Det 2 23ADS, 274th CCSQ, 213th EIS
    hyperbolic is offline LX Padiwan
    Los Angeles, Ca
    Thanks for the great writeup. Now I've got another weekend project.
    pdogg57's Avatar
    May 2006
    Quote Originally Posted by catzcradle View Post
    Quote Originally Posted by hyperbolic View Post
    thanks for the kind words guys. the lamp housing has a built in mercury switch that is tilt sensitive. it goes on when the hood is 1/4 of the way up and 3/4 of the way down.
    with all the tools and materials this mod can be completed within an hour.
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    Moved to knowledgebase. Great write up. Thanks for helping others.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    JaxHemi's Avatar
    JaxHemi is offline LX Padiwan
    Jun 2005
    I know it's been said a bunch of times in this thread, but this was another great write-up. You guys are awesome!
    pdogg57's Avatar
    May 2006
    Quote Originally Posted by JaxHemi View Post
    thanks Jax, its a pretty simple mod once you get all the parts/materials.
