PCM replacement *
This is very easy.
Tools needed:
13mm wrench or socket/ratchet combo
10mm wrench or socket/ratchet combo
Flat tip screw driver
Removal:
http://www.youtube.com/watch?v=jT8ZiLYydKM
I stopped just short of removing the bracket, you will need to remove this and install onto the new PCM as they do not come with it.
Installation:
http://www.youtube.com/watch?v=DCpZHICcWAA
Note that the plugs are color coded on both the connector and PCM.
"Use ta' could"
06 BSM SRT-8 Charger
SRT GRP I, II Sunroof
SOLD!!!!
