All LX's do not have an accessory controlled power source at the stereo harness. The radio is controlled by the car's CANBUS.
Tools:
a) If using push on taps, pliers
b) If doing the wrap tap, knife, electrical tape and tie strap (soldering iron if used)
Now to get to the cig lighter.
1) Remove the rubber pad that is directly infront of the ashtray.
Take something like a thin putty knife to get underneath it and pop it out.
Rememeber which way it comes out because it only goes one way in.
2) Pull off the radio bezel buy grabbing the cubby hole and with an light
upward pressure and pull straight out. It is only held on with clips.
3) Disconnect the AC controls and switches above the radio and put the bezel aside.
4) Then gently pull on the ashtray and it will pop out.
5) Then you can pop off the power connector for the lighter and tap into it.
!!!!!!!!! PULL FUSE #18 FIRST !!!!!!!!!
The wire that you want to tap into is the 16 guage red/orange wire.
There are a couple of ways to tap.
USING SQUEEZE TAPS
You have to be careful and get the correct gauge tap.
If you go too small you can cut the wire or too big it wont "bite" through the insulation.
You can get a tap from RadioShack(p/n 64-3052 $1.99 pkg of 10).
WRAP TAP
Using a knife, cut a ring around the wire so that you can pull the
insulation apart(go slowly so you dont nick the wires too bad).
Then take knife point and carefully poke through the wires making a hole.
Take the wire that you want to run up to the HU
and push it into the hole.
Wrap the excess around closing the hole.
Soldering the connection is the best way to connect the wires but is not required.
Now take electrical tape and wrap the connection, when you wrap the
wire to close the hole make sure that the ends are not poking up so that
it wont poke through the tape. Then what I do is take small tie wrap and
put at the end of the electrical tape that is capable of coming undone to
make sure it stays put.
Now if you have the smoker's group, the cig lighter will have power to it all the time.
If you have the smokers group the change to ignition control is very easy.
In the rear fuse block fuse 18 has 3 slots.
If you look at the pic the one fuse that is down from the others is the way you want it.
Install the radio, ash tray and radio bezel, reinstall fuse 18 and enjoy!!
