Written by Dr Bonz
Well, I went ahead and hard wired my Valentine One into the Magnum today. It was pretty easy and took me about 30 minutes to accomplish. I ended up using the front cig. lighter as my power source. You'll want to use a source that goes off when you turn the key off in the ignition and this one is perfect.
You can't use the one in the center console (between the front seats) if you have the "smoker's package" since it is ALWAYS on (even if you don't have the key in the ignition). You can correct this if you want by changing the fuse in the back of the car to a secondary position making it just like the one up front.
Here are the "tools" you'll need.
- A screw driver to help you unplug the wire harnesses from the back of the climate control and the cig. lighter
a wire stripper
a wire hanger to help you pass the wires.
First you have to remove the plastic housing around the radio and vents. It's very easy and just pries right off by unclipping the clips:
Just lift it forward. You'll have to reach behind it to unplug the three harnesses. One between the two vents and two to the climate controls:
It helps if you put the gear shift back into neutral since when it is all the way forward in park it tends to get in the way.
Next you pull out the ashtray panel that contains the cig. lighter.
You then unplug the wire from the back of it. There is this pain in the A** plastic clip that you have to pry off with a screwdriver.
There is a red (hot) and black (ground) wire attached to the back. Here is what the plug looks like unplugged. I'm holding the plastic clip that you have to slide out to remove the plug:
Next I buried the wire from the detector. I reversed the detector's hanging bracket so I could slip it under the headliner in front by the windshield. In this location you can still see the panel from your driving postion but it makes for a nice stealth location as you cannot see the lights from behind the car and it is difficult to see from the outside unless you practically put your nose on the windshield.
Also, it keeps the detector as high up as possible which is ideal for the best range in radar and lidar detection.
Tucked the wire under the A-Pillar cover.
Then down the door under the plastic cover:
