Page 1 of 5 123 ... LastLast
Results 1 to 15 of 64
    Cdn_Magnum's Avatar
    Cdn_Magnum is offline LX Guru
    Jun 2005
    KW, Ontario , Canada
    Front release for Magnum Hatch
    The credit for this mod goes to Ratman1648. He figured it out and I was the test bed for it.. Give him the beans
    The mod works are he predicted it would.
    I apologize for the poor pix. My Sony camera decided to start to die on me.
    You just need to solder a 4.7k (1/4watt) resistor on one lead of the switch. I soldered two wires to the switch with pin connectors on it to push into the release connector.
    The switch I used is a trunk release switch from a Crown Victoria (had the switch laying about)
    The switch technically can go anywhere if you want to run wire to the release connector.
    Remove the trim panel on the upper portion of the door sill next to the upper dash.
    Remove 1 phillips screw behind this trim panel.
    Remove one hex head screw about the middle of the lower dash cover.
    Pull the lower dash cover towards the drivers seat... its snapped into place. This should gain you access to the rear hatch release connector above the parking brake release. Drill the appropriate size hole for your switch. Mount the switch and use either 3M scotch lock connectors or small pin connectors (to push into the existing connector).
    Reverse your procedure to reassemble the dash.
    Instrument panel warning that the hatch isnt latched
    Time to install ... about half an hour
    Note** You do have to have the doors unlocked to get the release to work. This mod may or may not be useful to some because it does NOT open the lift by itself. Ratman1648 recommends stronger shock be mounted back there to assist in opening the lift gate (and removal of the counter weights). But it may assist in at least pre-releasing the lift for someone outside the back of the vehicle.
    Parts List:
    1 - momentary switch of your choice
    1 - 4.7K resistor 1/4 watt
    1 - location of installers choice for push button
    2 - pin connectors (anything that will fit in the existing connector will work)
    Russ
    - Falken 20" Explict Black rim,Falken 255 45 20 tires,8"LCD monitor headrests,12" LCD monitor in custom tri fold in back,custom made CIA,Infinity engine cover w/custom paint,custom painted centre bezel & console,custom lit cup holders, LED interior lighting & grill lites,HID's,300w sub amp w/custom enclosures,custom hand-made mesh grill
    FloridaRT's Avatar
    Ocala, Florida :-)
    Great write up, can you redo the photos in the near future??????????
    Thanks,
    Bob A.
    pir8magnum's Avatar
    pir8magnum is offline Magnum-animous
    Tampa Bay, FL
    My wish-mod is a key fob based button to release (and possibly open) the hatch. Im surprised they dont have it as an option, honestly.
    2007 Magnum SRT8 Steel Blue Metallic/Option groups 1,2,3/Roof Rack/Sirius/Everything but VES
    2006 Magnum R/T - GONE!
    Cdn_Magnum's Avatar
    Jun 2005
    Quote Originally Posted by FloridaRT View Post
    Thanks,
    Bob A.
    Its easy to pull the panels apart, so as soon as I buy a new camera I will update the pix . Again I apologize for the poor quality, but something was better than nothing.
    Cheers
    Russ
    ratman1648's Avatar
    ratman1648 is offline Dude, Where's my LX!?!?
    Portland, Tx
    just adding a link to the original thread
    Ya know that little connector under your headlamp switch?
    and the place that I think we can get some struts from
    http://www.suspa-inc.com/index.htm
    She will always be missed
    ^^^Somewhere in Houston^^^
    legmaker72's Avatar
    legmaker72 is offline Saving the world one leg at a time!
    May 2005
    Jacksonville, Florida
    Awesome work sguys...beans for both of you!
    Take care,
    Christopher
    ________ ________
    "I complained to God that I had no shoes, until I met a man with no legs"
    Super T's Avatar
    Aurora, IL
    Good find. Now I'm just awaiting a solution for getting it to open...
    ratman1648's Avatar
    Portland, Tx
    what is STRONGER STRUTS???
    and remove weights
    pir8magnum's Avatar
    Tampa Bay, FL
    So, could you install a remote switch in that space and then use a fob/keychain of some sort to activate it?
    Then my dream of having a remote opener would come true!
    Quote Originally Posted by Cdn_Magnum View Post
    Cheers
    ratman1648's Avatar
    Portland, Tx
    Quote Originally Posted by pir8magnum View Post
    if the switched wire provides a ground, I think if you connect it to the voltage sensor line with the resistor I'm pretty sure it will work
    pir8magnum's Avatar
    Tampa Bay, FL
    Hmm..I think this mod could have a whole new dimension!
    Anyone know where to get aftermarket remote switches?
    Quote Originally Posted by ratman1648 View Post
    ratman1648's Avatar
    Portland, Tx
    you can use one of these but since you need a switched ground(-) it would require the use of a relay
    pir8magnum's Avatar
    Tampa Bay, FL
    Well, you just went over my head..
    I'll let someone else figure it out and once they do, I'll install it.
    Or, if someone can figure out a theoretical way to do it, I could be the guinea pig for it. Let me know.
    Redfox0099's Avatar
    North Charleston, SC
    This is a good find....Good job
    MrHemi2U's Avatar
    MrHemi2U is offline LX Guru
    Jan 2006
    Pleasant Valley N.Y.
    Nice teamwork thanks.
    Before and After
