by jeffp
Easier that I expected. Order part 4806294-AA (was $13.36 at wycoffchrysler.com). It comes as a big plastic assy.
You'll need to remove the plastic pop rivets (white arrows) and trim retainer (orange arrow - is actually a hook that you can get easier from underneath with your finger) Carefully lift the trim up and remove the two 10mm hex nuts. A socket wrench works here.
The piece on the right is what you removed. Remove the same piece from the filter housing kit. It is seen on the left. The orange arrows indicate the mounting holes. The piece you are not using may be slightly differently designed than the one in your car. Mine had additional mounting holes in the car than was on the kit - rather than drill, the original works fine. Leave the one on the car in place. Use the new one as a trash can.
Carefully shift and wiggle the new filter housing in the space under the trim. You should NOT have to remove the wiper arms. It takes a bit of a shifting to get in as it is larger than the shroud you removed, but it will fit.
There is a slot/flange that holds the bottom of the housing in place. Be sure the filter holder is in the slot. Replace the 10mm nuts (orange arrows), use a flat wrench as it too close quarters for the socket. Do not over tighten, you just need to mildly compress the foam gasket. Slide the filter in place, close the filter door and replace the trim and asst pop and press rivets. Clean up and you're done!
The whole process took about 20 minutes and that includes stopping to get the camera and take the pictures.
sig by ElCobra44 The General Sherman / 2006 Charger R/T, Bright Silver
