After installing a trailer hitch there is no need to spend the $100+ for the Mopar or similar harnesses.
Using a basic 4 wire tail light converter you can hook up your harness in a matter of minutes. I used a Hopkins #46155 Basic Taillight converter, I got at the parts store for $26. Any 5 to 4 wire taillight converter should work.
No need to remove tail lights. You can tap all the needed wire rite at the fuse box in the trunk. There is a group of about a half dozen wires coming out the right side of the fuse box. They are the tail light wires.
Remove the fuse box so you can get the bottom off. Once you have opened the box use the supplied wire taps to connect the corresponding wires.
I probed mine and found:
Right Turn - White with Yellow stripe
Left Turn - White with Dark Green stripe
Tail lights/Parking lights - Purple
Brake - Red
Ground - I used the existing ground location for the battery.
You may want to probe yours to make sure they are the same.
Once you have all the wires hooked up neatly tuck them back in the fuse box and snap the bottom back on and reattach it to the car. I wrapped the converter in some foam and tucked it next to the battery.
When I'm not using the harness I leave it inside the car.
When I need it I just hang it out the tail gate.
Old GEEZERS Love cars TOO!!!" Yup, I'm car Crazy!!!
