HI guys,
Here are the instructions & Pics for removing the wheel inserts if you want to paint them.
Picture 1: To remove the lower inserts use a jewelers screw driver or credit card and insert as shown. You do not have to remove the air bag assembly to remove them (in case you only want to do the lower inserts only). Apply pressure up and the front two clips will pop. Then pull up the back on a slight angle and the back clips will pop out.
Picture 2: Insert removed, notice the four clips, 2 front & 2 rear. Now do the same for the other lower insert.
Picture 3: Disconnect the battery in the trunk, MAKE SURE YOU DISCONNECT IN THE TRUNK & NOT UNDER THE HOOD.
Pictures 4 & 5: Remove the 2 / 10mm bolts that hold the air bag assembly in place from behind the steering wheel. Adjust the telescopic wheel pulling it as far out as it will go to give you ample room to work. There are 2 bolts, one on each side of the wheel.
Pictures 6 & 7: After you have removed the bolts gently pull the air bag assembly out. There is enough slack on the harness so you do not have to disconnect them. Rest the assembly in the lower opening of the steering wheel (fits just right). You now have enough room to remove the upper inserts.
Pictures 8 & 9: Using a medium size flat screw driver insert the tip in the end as shown. As you gently pry up move the screw driver down to the bottom of the switch. Now apply pressure up until the insert pops up! When it pops it will scare the hell out of you but don't worry, the clips are very tight. Take your time.
Picture 10: Disconnect the harness to each switch by pressing on the clip as show and pull the connector straight up and out.
Picture 11: Shows the two triangle shaped clips that hold the switch in place
Picture 12: Now you have all 4 inserts removed.
Picture 13 & 14: Mask off the buttons on the upper inserts. Wet Sand and clean the inserts for painting. Apply 3 or 4 coats of the color of your choice followed by 2 coats of clear. I used Dupli-color 5oz. cans. Re-connect the insert wire harness, pop the inserts back in and re-install the air bag assembly. Now you can re-connect the battery and admire your handy work!
Picture 15: Completed wheel inserts, gauge trim, radio stack and shifter bezels.
1Likes
