Here is a step by step instructions of how to remove your seats from your LX. This is very easy thing to do to knock off another tenth or two off your 1/4 mile time. First time I did it, took me about an hour. Now I can do it in about 15-20 min.
Tools needed:
ratchet
extender
18mm socket
10 mm socket (star socket if you have one)
14 mm socket
15 mm socket
First thing I do is fold down the back seat, remove the trunk board, spare tire and jack.
Now I put the back set back up. Next remove the bottom cushion from the back seat. To do that, put your hand under the cushion and lift up until it pops loose. Do this on the passenger and driver side and then cushion will come right out.
This is what the clip looks like
It should look like this once you are done
Now it is time to remove the back part of the seat. There should be one bolt on the bottom that was hidden by the seat cushion. Remove this bolt with 18mm socket, you will probably need an extender too.
After that bolt is removed, fold the seat back down. There should be 5 bolts, remove these bolts with a 18 socket and the seat should come right out after that. Screw the nuts back on the studs after the seat is removed so you don't lose them.
It should look like this once the seat is removed
Now time for the front seat. Now your seat may be a little different than min because I don't have a power/heated seat but I'm sure it couldn't be to different. Start by removing the plastic covers that cover the bolts on the front part of the seat.
You now have to remove 2 bolts from the front part of the seat. Use a 14mm stocket to remove the bolts seen in the pictures below.
Now go behind the front seat. There should be two bolts there. Remove these with a 15mm socket.
After the bolts are loose, tilt the seat back so you can get to the wires underneath. There is two things you have to unplug seen in the picture below. Pull the red switch out, then you have to squeeze the red switch and pull out.
Now before you can remove the seat, you have to unhook the seat belt. Pop the plastic guard off where the seat belt connects to the seat. Then use a 10mm socket (star socket if you have one) with an extender to remove the bolt.
One last thing before you remove the seat, remove the head rest. To do this tilt the seat back all the way. Pull the head rest up all they way, then push in the two buttons at the same time and pull it out.
Now tilt the seat all the way forward, lift upward and turn it 45 degrees and take it out through the front seat. Be very careful not to scratch your car with the seat bracket. Make sure you are very careful with the seat after you remove it. Don't drop it down hard, don't sit on it or bump it on anything. These seats have air bag sensors in them and if you hit the seat hard or sit on it when it is out of the car it will have to be recalibrated at the dealer. Your air bag light will be on as long as you have the seat removed. Once you put it back in the car the light should go off. If it doesn't go off, you will need to have it recalibrated.
After the seat is out, I bolt the seat belt down with one of the bolts from the seat so that way it doesn't smack me in the face when I am driving.
When you are done it should look like this
