Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
    Jun 2005
    IN THE ETHER
    Modified Window Controls
    Well I finally did it. I was driving the other day. I had my left hand on the wheel and the my right on the shift. I was having fun with the SuperChips and shifting. I went to roll down my window. I instinctually went for the center console. That is where the controls are on my wife's Mercedes Benz. Then I had to swith hands on the wheel to actuate the switch. I had to switch my hands again to drive the way I was driving. Then it hit me. Time to move door mounted window controls to the center console. I made a couple quick measurements to see if it would fit. It was a perfect fit. I took me about 8 hours total to do this mod. 4 hours one day and 4 hours the next. Below is a quick run down on how I did it.
    1) Make two wire harnesses 16 feet long with 16 gauge wire(found at any auto parts store). One harness needs 7 wires and the other is 6 wires. Bunch them together and wrap with electrical tape. This is needed to keep the wires together when you thread them through the car.
    2) Remove door panel. Snake both harnessed through the door and hinge area. Inside the vehicle, you have to remove the parking brake mount to get to the hole to get the harnesses. Not hard to do. Snake the wires to the center console area. (Sorry, I did not take any pictures. This is straight forward and not hard to do.)
    3)Take apart the window control module. And set aside.
    3) Make some connectors that will fit into the existing window control harnesses. I had to custom make some small connectors. I shaved down some standard connectors to make them fit. I soldered them on to the wires and connected them to the existing connectors.
    4) Identify and match the correct wire from the harness. Solder them directly to the window module circuit board being careful to connect them in the same connector.
    5) Cut and trim the center console. This was the hard part. It was trial and error. Trim, test fit, repeat. Once I was satified with the location, I glued it together with JB Weld expoy. Very strong stuff. Once everything is cured put it all together.
    6) Just cover the area with a piece of black plastic. I used the rubbery material from the cubby hole insert. I just trimmed it and JB Weld to the cover. Its a great place to put a cell phone and it had the rubbery stuff so it wont slid around.
    This was a quick description on how I did it. There were some steps that I did not take any pictures. I was on a roll and I forgot to stop and snap a few shots. Its not hard to do. Just need some patience and a lot of planning. You can contact me if you any questions.
    Jose
    jwserrano@earthlink.net
    951.775.8568 cell
    PEACE OUT YO!!!
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    That looks incredible. Nice work. Very professional looking.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    Mighty Noid's Avatar
    Mighty Noid is offline time to paint the car soon!!!
    Aug 2005
    SoCal
    Awesome write up and install. I hope to see you ride at a M&G soon. I missed it at the Spring Fling...
    Thank you Bigal470
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Man shag, thats extra sweet there buddy. One fine upstanding job. Very, very clean. WOW, cheers to you
    7thS0N's Avatar
    7thS0N is offline She's done heck darnit!
    Tampa, FL
    Neato! I can't believe that fit so well!
    Performance: AirHammer, Hi-flo cats, Bassani exhaust, Predator tuned, Mopar perf springs, Hotchkis sways, BT catch can, EGR delete
    Interior/Looks: Custom embroidered Katskins, custom embroidered console & cargo covers, tinted tails (Charg-um), Upper and Lower grills (NC-SXT), 'Cuda stripes, 20" Torque Thrust-M's, MoPower Shaker, MoPower Chin spoiler, PAINT!
    Tunes: Pioneer F90BT, JVC Arsenal KS-AR8004D + Kenwood KAC-7204, Infinity Reference setup including 2 10" subs in custom embroidered RobbyHo enclosures
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    Now this is innovation!! I loikey!! This is the kind of koolness that promulgates intelligent modification!.
    Good going!
    And the dead shall walk
    NautcaSprt6's Avatar
    NautcaSprt6 is offline Wish you the best BigBob
    Aug 2005
    Brooklyn NY
    That looks great.
    It looks like it came stock.
    I would love to do that, but I have a habit ofshifting hands constantly so it would not matter to me.
    Im a practical joker, so dont take anything seriously. GOT IT. GOOD.
    Big Thanks to: | www.BilletTechnology.com | www.TVandNav2Go.com | www.VIP300C.com
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    hehehe, you just told a cop your shifty. LOL
    MrHemi2U's Avatar
    MrHemi2U is offline LX Guru
    Jan 2006
    Pleasant Valley N.Y.
    One of a kind mod (for now) good job. It looks stock.
    Before and After
    Jun 2005
    IN THE ETHER
    Thank you every one. It really was a labor of love. It was fun and I think it turned out pretty good.
    Quote Originally Posted by MrHemi2U
    For now is true. But I can say that I was the first.
    PEACE OUT YO!!!
    MAGNUM8R's Avatar
    MAGNUM8R is offline Yes I am a pirate, 200 years too late
    So. California
    Pretty cool mod Jose, very pioneering, more huevos than I've got!!
    An over 40 victim of fate.
    '8R'05 Magnum RT Midnight Blue Pearl
    KW V 2 , Hotchkiss Sway Bars, CF Airhammer intake,T Rex Billet Grille, Body color Airtab Vortex Generators, Chromed stock 18's BFG KDW 255/55/18 Tires,Avon splash guards, Gibson Performance Stainless SteelHeaders, GibsonCat back, SC 91 Performance tune.
    Hi Flo Cats
    BUTWEET's Avatar
    BUTWEET is offline GOOD MEAT TAKES A LONG TIME!
    Bothell, WA
    I've been waiting to see this Jose. I'm in awe of the professional looking job. Nice work man!
    MY MEAT WILL MELT IN YOUR MOUTH....NOT IN YOUR HANDS! ENJOY THE Q.
    SmoovC's Avatar
    SmoovC is offline M45 Maniac
    Apr 2006
    Graham, Kracka'!
    Very, very nice! Looks factory, & very nicely executed.
    2006 Infiniti M45: Diamond Graphite Metallic, Premium Package Option Group w/ Mobile Entertainment System, Tein H-Techs & KYB Lowered, Magnaflow Exhaust
    2000 Dodge Dakota C/C R/T: Flame Red 5.9L, 1 of 800 Produced, Belltech Lowered, 20" R/T Replica Wheels, Flowmaster Exhaust
    More pics at:
    Visit us at:
    FOHN_JARGO's Avatar
    FOHN_JARGO is offline Ka CHOW!
    Bella Vista Arkansas
    Awesome look. Great job. I like the idea of the cell phone pocket in the door instead of the console. Now that you've moved the buttons, do you find yourself playing with them?
    If I am next to a Magnum and the windows keep going up and down can I assume it's you!?
    The Magnum has a soul. It has a personality, something all too lacking in the automotive transportation appliances everybody else is offering.
    Jun 2005
    IN THE ETHER
    Again thanks. I keep forgeting to write some things.
    The cool thing is that I can refert back to factory whenever. All I need to do is get a new window module and center console. Pop off the black cover on the door, put in a new module and hood it back up to the the connectors. I was took chicken cutting off the original connectors. Thats why I went with the soldered on peices. Now put on a new center and VOILA! back to stock.
    PEACE OUT YO!!!
